LCD Bargraph help — Parallax Forums
LCD Bargraph help
tgraz34tgraz34 Posts: 16
edited 2010-03-07 18:00 in BASIC Stamp
This code dispays RPM and a percentage of how fast your going with a bar graph. How can i make this code so that the bar graph displays on a 4 x 20 LCD screen instead of a 2 X 16. So the bar graph doesn't stop at the 16th position and keeps going till the 20th.
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] I/O Pins ]-----------------------------------------------------------
LcdPin         PIN     15
SpeedIn        PIN     3
' -----[noparse][[/noparse] Constants ]----------------------------------------------------------
T9600          CON     84                    ' True, 8-bits, no parity, 9600
Capture        CON     5000
LcdCls         CON     12                    ' Form feed -> clear screen
LcdCr          CON     13                    ' Carriage return
LcdOff         CON     21                    ' Turns display off
LcdOn          CON     22                    ' Turns display on
Line0          CON     128                   ' Line 0, character 0
Line1          CON     148                   ' Line 1, character 0
Define         CON     248                   ' Address defines cust char 0
LcdBLon        CON     $11                   ' Backlight On
' -----[noparse][[/noparse] Variables ]----------------------------------------------------------
rpm            VAR     Word
pulses         VAR     Word
custChar       VAR     Nib                   ' Custom charcter selector
index          VAR     Nib                   ' Eeprom index variable
dotLine        VAR     Byte                  ' 5-pixel dotted line
cursor         VAR     Nib                   ' Cursor placement
value          VAR     Byte                  ' Value to be graphed.
charCnt        VAR     Byte                  ' Character counting variable
line           VAR     Byte                  ' Line0 or Line1
percent        VAR     Byte
highVal        VAR     Word
' -----[noparse][[/noparse] Initialization ]-----------------------------------------------------
PAUSE 100
SEROUT LcdPin, T9600, [noparse][[/noparse]LcdOn, LcdCls, LcdBLon]
PAUSE 5
custChar = 3
dotLine = %11111
GOSUB Def_Horiz_Bar_Char
line = Line1
pulses = 0
highVal = 3500
DO
  GOSUB Acquire_RPM
  value = rpm / 44
  GOSUB Bar_Graph:
LOOP
Acquire_RPM:
  COUNT SpeedIn, Capture, Pulses
  rpm = (pulses * 12)
  percent = (rpm / (highVal / 100))
  RETURN
Bar_Graph:
  value = value MAX 80
  charCnt = value / 5
  custChar = 3
  IF charCnt > 0 THEN
    FOR cursor = 0 TO charCnt - 1
      GOSUB Disp_Cust_Char
    NEXT
  ENDIF
  cursor = charCnt
  custChar = value // 5
  LOOKUP custChar,
         [noparse][[/noparse]%00000, %10000, %11000, %11100, %11110],
         dotLine
  custChar = 2
 IF (charCnt + 1) < 15 THEN
    FOR cursor = (charCnt + 1) TO 15
             [noparse][[/noparse]line + cursor, " "]
    NEXT
  ELSEIF value = 80 THEN
           [noparse][[/noparse]line + cursor, 3]
  ELSEIF charCnt = 14 THEN
    SEROUT LcdPin, T9600, [noparse][[/noparse]line + 15, " "]
  ENDIF
  RETURN
Def_Horiz_Bar_Char:
         [noparse][[/noparse]Define + custChar]
  FOR index = 0 TO 7
    SEROUT LcdPin, T9600, [noparse][[/noparse]dotLine]
  NEXT
    SEROUT LcdPin, T9600, [noparse][[/noparse]134, DEC rpm, " RPM    "]
    SEROUT LcdPin, T9600, [noparse][[/noparse]164, DEC percent, "%  "]
  RETURN
Disp_Cust_Char:
         [noparse][[/noparse]line + cursor, custChar]
  RETURN
    edited 2010-03-07 13:58
    To start:·look at the program and then hunt out the stuff that implies '16'
  • tgraz34tgraz34 Posts: 16
    edited 2010-03-07 13:59
    tried that... but thanks
  • hover1hover1 Posts: 1,929
    edited 2010-03-07 14:29
    Hint.. 16 = 0>15
    Two main changes will be the lines
    [s]value = rpm / 44 [/s]
      value = rpm MAX hiVal / 35      ' value can go to 100 when hiVal is 3500
    and
      [s]value = value MAX 80[/s]
      value = value MAX 100   ' 100 bars
    Also there will be changes in the program segment that begins with
    where numbers 15, 80 and 14 should probably(?!) be 19, 100 and 18, respectively.
    Tracy Allen
    www.emesystems.com
