My article is going to Nuts and Volts! {updated title}
To anyone that feels up to it, here is my article. I have gone over it and edited it, but I would like someone more experienced to go over it for me before it is sent off. Thanks!
Micro
Don't click on this.....
Use the Propeller icon!!
Post Edited (microcontrolled) : 3/12/2010 11:19:34 PM GMT
Micro
What level of review would you want? Meaning, review it from the view of a beginner? Expert?
Would you wish grammar and structure included?
I can be *really* "anal"...reviewing documentation is part of what I do at my day-job.
DJ
As I understand it, the editors will format your article in columns around whatever other pictures, ads, etc.
...reading...
Edit:
Initial reaction to it is that you left me wondering how RFID works.
The difference between an Instructable and a column is the education about the items used,
in this case, the how RFID works. Do some additional research on what is happening there and add
it to the beginning of your article. -- All in all, so far so good.
I'm not an editor so to speak, as I have an author who edits me to make sure I make sense as well.
I'm sure others will be able to help more in that regard. [noparse]:)[/noparse]
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 3/2/2010 9:28:40 PM GMT
Wow, if that is your first attempt at an article I certainly look forward to what else you may write next!
I can offer a few suggestions in regards to what has worked for me when submitting an article...
Although your formatting looks great you will want to make it all flow through as a single column like a normal document. The formatting you have (bold type, different font for the command example) is perfect. Just keep the actual article content to text only with minimal formatting. OBC nailed it when mentioning the editors laying out the article will handle formatting of the text since they need to flow it around ads, pictures, etc.
When I submit an article I will zip it up and add a number to the file name so they can make sure all the parts come through. One zip has the actual article, text, and programs while the other(s) contain the images (jpg, gif, bmp). I'll send extra images so they can pick the most appropriate ones when they layout the article. It's best to let them know it's coming ahead of time.
The offer that DJ made above sounds good and in my opinion I would prefer someone really look at all the details (grammar, punctuation, etc) since the details can make all the difference. Don't take it as criticism since it is easy to overlook details if you've been staring at it for a while. I've been fortunate enough to have some friends that enjoy proofreading my work before I send it out and it can be invaluable to get another persons perspective.
You should have the example program code to go with it as a download for their website. As long as people can download the code they can build their own and also follow the listing as they read how it works. Sometimes it makes sense to add more program examples but it really depends on the article and I still need to finish reading it.
One thing that may help is if you add a BOM (Bill Of Materials) at the end of the article that lists all the part numbers and part sources in one place.
Looks like you are off to a great start!
Robert
@davejames: Thanks for the offer! You just tell me what I need to make it acceptable for a magizine.
Thanks a lot!
Micro
Post Edited (microcontrolled) : 3/3/2010 1:14:06 AM GMT
But how does RFID actually work??? :
Keep going!
OBC
http://en.wikipedia.org/wiki/Radio-frequency_identification
http://www.amazon.com/RFID-Dummies-Patrick-J-Sweeney/dp/076457910X
I'm sure there are many others...
Since some people won't know what SPIN is you may want to mention that you were able to accomplish the task using the native built-in SPIN language without the need to get into lower level assembly code. It doesn't seem to mention if you took advantage of multiple cogs. If so then you've leveraged a unique aspect of the Propeller and should mention it.
Robert
When I send them articles I name the graphics files things like "Figure1.jpg" which correspond to the figure name in the text. You'll also want to try to refer to your graphics by name in the text. When they format your article your graphics may be on different pages than the text reference.
I'm looking forward to reading it!
Jim-
Signature space for rent!
Send $1 to CannibalRobotics.com.
Check it out and see what you think!
Thanks!
Micro
Post Edited (microcontrolled) : 3/3/2010 1:13:43 AM GMT
One major problem is the length of the paragraphs; they are too long, making the article difficult to read.
Leon Heller
Amateur radio callsign: G1HSM
Post Edited (Leon) : 3/3/2010 12:08:33 AM GMT
The length of the paragraphs shouldn't be too hard to sort out. For the hardware section look for logic places to break it up. For example separate the electronics from the mechanical section.
Keep on going....
Robert
It's probably not a good idea to post your draft publicly like this. The reason is that most publishers insist on "first publication rights", i.e. they won't accept anything that's already been published. Technically, posting on a public forum counts as a "publication". It would be better just to solicit the proofreading here and email the draft copy, including a copyright notice, to those who are interested.
Robert
Robert
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I have all the pictures on an upload site I created because they do not upload fast on e-mails. Do they allow a web-based picture?
Here is an example if the FILELIST.txt file I sent for an article that was published on BOB. I included this file in each of the ZIP files I sent in. Once they unzip all of them they should have everything listed in that file.
File list:
Article:
BOBpart2.doc - Article
Contact.txt - Author Contact info
Bio.txt - Author BIO
Images:
bobbase.JPG - Picture of how everything mounts to base
topobatterymonitor.JPG - Picture of original TOPO Battery Monitor board
powertop.JPG - Picture of the custom power board
powerbottom.JPG - Picture of custom power board (bottom)
powerlabel.JPG - Picture of labels for power board
powerwiring.JPG - Picture showing power wiring
sonarmuxtop.JPG - Picture showing Sonar MUX board
sonarmuxbottom.JPG - Picture showing Sonar MUX board (bottom)
sonarmux.JPG - Picture showing how boards look inside robot
badwire.JPG - Picture showing poorly crimped connections
encoder.JPG - Picture of original drive motor encoder
Code Fragment for Article Text:
Sonar_Select.txt - Subroutine to demonstrate sonar select MUX board.
Schematic Drawings:
BOB_Power.bmp - Schematic of custom power board
BOB_SonarMUX.bmp - Schematic of custom Sonar MUX board
This should give a pretty good idea of what you should have in that file. Depending on the article you may or may not need all the sections. Everyone does it a bit differently but this worked for me. It was in the March 2008 SERVO.
Robert
6 months? 12 months?
Micro
Sounds like you are well on your way. If you haven't contacted the magazine yet you probably should so they know to expect something. After you send it you can check in to make sure all the pieces made it there ok. Once they receive it they will let you know what they think. The timeframe for publication varies from magazine to magazine and depends on how many articles are ahead of yours and for some if it fits in with the theme of the issue. Also, if for some reason there is an opening it may get slipped in sooner. Usually figure at least 2-3 months but it could be more. If they like it and want to use the article then ask them approximately when it may come out.
Also, if they need other pictures or clarification on any points that is something you can discuss with them after it is submitted.
You've taken a big step forward and I hope it works out. Thing like this will look great on a resume for you and can lead into other things!
Robert
Another contributor to one of the mags also wrote books on computing. He lived near me and a friend of mine visited him to ask him a question about something in one of his books; he was was a bit taken aback to find he was wearing a dress! I mentioned this to the editor and he told me that said contributor was writing the articles and books to finance a sex change operation.
Leon Heller
Post Edited (Leon) : 3/5/2010 7:34:05 AM GMT
[noparse][[/noparse]You have a bunch of guys about to turn blue here.]
Leon Heller
Well, I've never considered getting a sex change, but I have on occasion pondered a possible enhancement or two. Leon, are you telling me that perhaps there's still hope? Is writing for Nuts and Volts the way to fulfill my lifelong dream of standing out in a crowd?
cgi.ebay.co.uk/Understanding-the-68000-By-Heller,-Leon_W0QQitemZ220539395158QQcmdZViewItemQQimsxq20100113?IMSfp=TL100113238002r28777
I got £1,500 for it (outright sale, no royalties) which was a lot of money at the time. It only took me about three weeks to write it, which was a pretty good hourly rate.
Leon Heller
Post Edited (Leon) : 3/5/2010 2:37:38 PM GMT
It is nice to be in print and a few extra dollars can help with unexpected expenses. In my case the check arrived the same day my wife came back from the dentist and told me she had to get a crown. Even after insurance it adds up so.. poof! There went the money from the article. Sigh... I'm still glad that I did it and have some other articles in the works.
Robert
