2V Overshoot on breadboard setup. Is this 'normal'? - Page 2 — Parallax Forums
2»
    edited 2010-03-02 12:42
    A while ago the chips seemed much more sensitive to spikes, especially the negative ones.
    Those spikes are probably already being snipped off by the Prop's protection diodes.
    Style and grace : Nil point
  • LeonLeon Posts: 7,620
    edited 2010-03-02 12:58
    I have a 100 MHz scope, but I can reduce the bandwidth to 20 MHz so that I don't see nasty things like that.
    Leon Heller
    Amateur radio callsign: G1HSM
    edited 2010-03-02 14:40
    That is much better, except I would put a ceramic 100nF AND a 10uF+ electrolytic on BOTH sides of the prop.
    So on the side you have the ceramic, also add an electrolytic.
    On the side you have the electrolytic, add the ceramic.
    Some overshoot is normal.
    greitz said...
    Bill Henning said...
    Please put a 100nF ceramic, and at least 10uF (up to 33uF) electrolytic cap on each side of the propeller, between the propeller's Vcc and Vss pins.
    Did I place the caps in the correct places? I wasn't sure if you meant, one 100nF ceramic on one side and one 10 to 33uF electrolytic on the other side, or two on each side.
    Is there a schematic that I can follow that shows the capacitors? I have been using the 'Typical Connection Diagram'.
    I also added a LM2937 3.3V regulator. Thanks for the tip, previously I fried one of my props (first time) when I accidentally raised the voltage to about 8V.
    Cluso99 said...
    I missed the overclocking bit. I just would not overclock a breadboard. And you MUST have 0.1uF decoupling ceramics at both sides of the prop power/ground pins with short leads. A 10uF tantalum on each would not go amiss either.
    This setup is using the standard 5MHz crystal.
    Overall, it looks better but still overshoots by about a volt.
    I also tried it with the 6.25MHz Crystal and it looks about the same. Maybe slightly worse ripple, but barely noticeable.
    Thanks again,
    graham
    Edited to add test with 6.25MHz crystal and voltage regulator
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-03-02 17:09
    greitz,
    I should have looked at this closer....
    A square wave is actually an infinite series of sine wave harmonics added together. Scope probes, power leads, IC internals, and several other factors can create parasitic filters that can emphasize (tune) and de-emphasize (de-tune) some of the harmonic components associated within the square wave.
    en.wikipedia.org/wiki/Square_wave
    "...If the system is overdamped, then the waveform may never actually reach the theoretical high and low levels, and if the system is underdamped, it will oscillate about the high and low levels before settling down..." <- Which is what we see.
    en.wikipedia.org/wiki/Damping
    ...In this particular situation it is better to be under damped simply because you can add resistance to 'dampen' or attenuate the signal, where as being over damped your signal has an inadequate amount of drive strength from the source to begin with.
    See the attached images... 'P0.jpg' is measured directly off of P0 where as 'P0 with 100 Ohms.jpg' has a 100 Ohm series resistor off of P0.
    Also is the attached program used to generate the signal on P0.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/2/2010 5:33:37 PM GMT
    3456 x 2592 - 1M
    3456 x 2592 - 1M
  • hover1hover1 Posts: 1,929
    edited 2010-03-02 17:15
    It looks like carbon is you friend!
    Jim
  • jazzedjazzed Posts: 11,803
    edited 2010-03-02 17:20
    Peter Jakacki said...
    Ignorance is bliss and a little bit of ringing never hurt anyone, or so said Quasimodo.
    hover1 said...
    Of course too much of anything is bad for you.
    @grietz,
    It may not matter, but your probe calibration signal should be a nice square-wave.
    Use the probe trim adjust to make it square if possible.
    Also, make sure your probe is set to 10x for best measurements.
    Post Edited (jazzed) : 3/2/2010 7:12:35 PM GMT
