A/D Converter overheat due to battery wires in close proximity?
Im running a 14.8 volt battery with 30 Amp output for a motor and my basic stamp and speed controller wires are all in close proximty to the heavy battery wires going to the motor.
Ive been running my motor for a while, but then after recharging the battery, the signal began to jump around and now my A/d converter basically overheated a (expletive) load.
Do you think the high amps from the battery wire interfered with the analog signal coming in from my speed controller? ...which is a little force sensor.
If so, how do I isolate the wires? just more insolation?
Please help!
Thanks.
Please help!
Thanks.
Motors are very noisy. VERY noisy. I had a pencil sharpener next to my laptop once. When I sharpened a pencil the computer would go nuts and lock up...... motors.... they noisy [noparse]:)[/noparse]
"puff"...... Smile, there went another one.
