Vss and Vdd Pins
Alexander (Sandy) Hapgood
There are two Vss and two Vdd pins on the DIP version of the propeller chip (P8X32A-D40). These are: 9 and 29 for Vss, 12 and 32 for Vdd.
The P8X32A-Q44 and P8X32A-M44 have four of each.
Do all Vdd pins and Vss pins need to be connected for the chip to be powered correctly or are they connected internally. Internally is the answer I'm wanting to hear! [noparse]:)[/noparse]
Sandy Hapgood
Sandy Hapgood
Leon Heller
Amateur radio callsign: G1HSM
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Sandy
"Give a lie twenty-four hours start, and it will take a hundred years to overtake it.
" (C.F. Dixon-Johnson, British author of the 1916 book, "The Armenians," appalled over the deceitful practices of his book's subject.)
www.tallarmeniantale.com/
Ray
Style and grace : Nil point
Leon Heller
http://forums.parallax.com/showthread.php?p=864936
Ray >> I saw the connection scheme illustration in the user manual and after reading the above thread wondered why the Parallax team had not closed loop on the documentation to prevent misunderstandings.
it's a good practice to connect all Vss together and all Vdd together
to reduce noise effects. This becomes especially important with
multiple prop chips. My early experiments have confirmed this.
humanoido
It might make the PCB layout a bit more "convenient" to pick and choose if they get used, but don't do it.
Leon Heller
I guess the next question to ask is, why does the chip have VDD, and VSS on both sides of the chip? Is it to balance out the pins on the dip version LOL?
Ray
It's to help supply a low impedance path to both sides of the die. The smd chips have 4 sets of power pins. By not connecting a pin, you are asking the power paths across the die to carry far more current than they need to. This can have nasty side effects (like cooking the clock PLL).
Always connect all power pins. Always decouple all power pins (connect a capacitor between them as close as is practical to the chip). Now I'll leave myself nicely open to ridicule by saying a good rule of thumb is a minimum of 0.1uF on each set of power pins. Low ESR caps are best. I just use monoblock ceramics as I buy them in packs of 1000.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
There is nothing wrong in what you say. In the good old days the chips only had one set of power pins, byt then they didn't have so much in them and clocked slower. CMOS has much "sharper" switching edges and it is these edges that require good solid energy to be available. 0.1uF close in is a very good start, a larger "bulk" cap nearby is good.
position of decoupling capacitors?
No decoupling is just not an option.
Minimal decoupling will get most things up and running when the conditions are near to perfect.
Better decoupling will get all things rolling along even when life is a bit more hostile.
Heavy decoupling will be needed when life is going to be really mean, as in overclocking.
You can worry about all sorts of things, and build in bits to counteract them, but a 0.1uf ceramic on every Vdd and Vss, on every chip, together with a 10uF for the Prop and for every other 5 ordinary chips (evenly distributed) will be a solid start.
Post Edited (Toby Seckshund) : 2/28/2010 2:56:05 PM GMT
http://forums.parallax.com/showthread.php?p=865046
... Inside the chip die itself, there is what's commonly called IR drop. It represents current drop due to resistance over a distance. The length wires inside the Chip have so many Ohms per square (typically .08 Ohms) and contribute to the internal 'R' value. By utilizing ALL of the Vss and Vdd pins you effectively are using the external wiring as a parallel resistor within the internal resistance of the wire within the die, thus reducing the IR effects over the entire chip.
Beau Schwabe
IC Layout Engineer
Thus your guessing about the value making the process a black art.
Nyamekye,
Without all those £20K+ cute toys to see what makes the differences, or not, it lurches towards educated guesswork.
Fortunately, lobbing in a load of caps is so easy, although I suspect that having good quality energy available to an insuficient number of power pins, could make it worse for all those internals. So as everybody says, use all the power pins with some 100nF caps.
Right, I'm off to find some apple juice, if those pesky elves haven't nicked it, again.
Post Edited (Toby Seckshund) : 2/28/2010 8:10:55 PM GMT
Toby Seckshund,
"I was always told that you should have "layered" decouplers that make up for the deficiencies in the others. That is, to have a 100pF + 1nF + 10nF ......... allowing for all the impedances in all of the frequencies." - That is correct, but one reason this is true is due to the internal resistance within each capacitor which creates an·RC·filter at different frequency poles.· If the capacitors had no internal resistance, then it would just be an accumulative capacitor event.
Yes, you can place several caps and you should be in good shape, but you should at least know why doing this helps.· It's not guess work if you understand the problem and know which direction to go with the solution.·
Beau Schwabe
IC Layout Engineer
Nice picture.
BUT I have one question?.
Have COG's same placement on Die in conjunction to Power PIN's.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Here is an actual view of the current die...
http://www.parallax.com/Portals/0/Images/Prod/0/PropDieDiagram.jpg
...you can see the power ring that goes around the outside perimeter of the die.· The picture that I posted earlier was just to get the idea across.· Please note in actuality, power and ground is picked off in multiple locations around the die.· In the current Propeller this means that some of this power passes through from one COG to the next as sort of a 'grid' archetecture.· The Propeller II will likely be closer to the example image I posted with a better power grid structure throughout the Chip.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 2/28/2010 10:22:22 PM GMT
Sapieha
Thanks for the pics, Yes I do know something of the Minutiae of the problems, I was for many years in microwave transmission.
I was just trying to stay at the hobbyist level.
Good luck with the layouts, and if you mistakenly produce a few PLCC84 prop1 Bs, I'll have them.
