where to learn Propeller Assembly language — Parallax Forums
octaloctal Posts: 67
edited 2010-02-28 19:57 in Propeller 1
Hello,
I just wanted to know where can I find resources (books and tutorials, paper books will be better) to learn Propeller asm?
Regards
  • octaloctal Posts: 67
    edited 2010-02-28 11:29
    Well,
    I checked the forum threads and found this one http://forums.parallax.com/forums/default.aspx?f=25&m=335240 witch contain a link to http://forums.parallax.com/forums/default.aspx?f=25&m=209237
    The link is named "Machine Language Tutorial - deSilva"
    I think you should rename it to something like "Assembly Language Tutorial - deSilva" ... cause I searched the forum using "search" functionnality for "Assembly language" and dint got this one in results. I think that most users willing to learn assembly language will search for "Assembly language" instead of "Machine language" ...
    Regards
  • tdeyletdeyle Posts: 85
    edited 2010-02-28 13:40
    Take a look at this webinar: www.parallax.com/tabid/742/Default.aspx
    There's an assembly language webinar that was put on in December that covers Propeller Assembly fundamentals. Click on the View Webinar Archive Videos button, at the bottom of the next page, there is a link to the Propeller Assembly Webinar Video.
    Theo
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2010-02-28 14:50
    You might also enjoy my 4 step program:
    http://forums.parallax.com/showthread.php?p=647408
    It just consists of 4 little programs each of which show you how to do something useful.
    Step 1: Flash an LED
    You will learn:
    1. How to start an assembly cog
    2. A simple way to load a variable into that cog on start up with no funny business (very handy)
    3. How to set a pin as an output
    4. One way to make a pin high
    5. How to use waitcnt in assembly
    Step 2: Setting pins
    You will learn:
    1. How to create masks for single and multiple pins from variables.
    2. How to set up the dira register using these masks
    3. How to set outputs high with OR and a mask
    4. How to set outputs low with ANDN and a mask
    5. How to toggle outputs with XOR and a mask
    6. How to use muxc and muxnc to set and clear bits and a mask
    Step 3: Hub to cog data transfer
    You will learn:
    1. How to pass an address for hub variables to assembly code on start up.
    2. How to load these variables from hub to cog within assembly using rdlong.
    3. That the addresses are byte wise in assembly
    4. How to write functions that can be used in spin to modify the global hub variables.
    5. How these might be used in a simple spin function
    Step 4: Cog to hub data transfer
    You will learn:
    1. Review how to pass an address for hub variables to assembly code on start up.
    2. How to load data into hub ram with wrlong
    Yet more flashing LEDs in a knight-rider style this time.
    This is basically the most important stuff I learnt (with difficulty).
    Graham
    edited 2010-02-28 15:37
    Thank you very much for these links. I'll study all that this week [noparse]:)[/noparse]
    Regards
  • JonnyMacJonnyMac Posts: 9,553
    edited 2010-02-28 17:57
    After you've got a handle on the basics my programming column in Nuts & Volts may be helpful; almost all of my columns (starting last year) include assembly code and I explain it. Not a tutorial, per se, but still good information (I hope...).
    www.parallax.com/Resources/NutsVoltsColumns/TheSpinZone/tabid/781/Default.aspx
    Jon McPhalen
    Hollywood, CA
    edited 2010-02-28 18:05
    "machine language" -vs- "assembly language" would be an interesting discussion to have with DeSilva, who I hope is off somewhere having a great time, given his fine contributions here.
    The post below DeSilva's contains my Assembly Language Primer for the Absolute Beginner. I was authoring some real basic stuff, while he was knocking out a rather good intermediate to advanced document. We chose to put them together, in the hopes that people find both useful, depending on their skill level. Mine has a lot of basic ideas explained in a good read that isn't too thick at any one time. Use it as an intro to the topic.
    I really like Phil's program, and used it to get started with PASM myself, as it was written right when I was wanting to go down that road.
    8x8 color 80 Column NTSC Text Object
    Another useful tool, perhaps, is the PropBASIC compiler. If you can code something in BASIC you can study the output of the compiler to see the translation to Propeller Assembly.
    Jon McPhalen
    Hollywood, CA
