custom plastic box.
Any idea were I can get semi transparent plastic with a black and white design printed on it?
I wish to make a light box for taking pictures of products. Material needs to be strong not flex. Semi transparent so it will defuse light shon through it.
I can provide artwork as gerber or png format. Image must be printed accurate to size.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
I will borrow a 500W work light tomorrow and print the scale on vellum paper and see what the results are.
Will have to go searching for spray adhesive. Never even herd of it before.
edit: Walmart apparently sells it so will see if they have in stock. Home depot is next door so between the 2 I should find it.
Post Edited (mctrivia) : 2/27/2010 8:42:45 AM GMT
500W sounds like an awful lot of light. If you backlight too heavily, all you will see is a silhouette of your subject.
BTW, I just got one of these: www.thinkgeek.com/electronics/cameras-photography/a205/. It's well-made and inexpensive, and the side-lighting is diffuse enough to produce shadowless images without having to backlight.
yes 500W is a lot. was actually think of using that for the top and my flash on the bottom.
