MAX6675 Assembly code
I am trying to interface with a MAX6675 Thermocouple chip and having some issues. The spin code works fine, but when I try to translate it over to assembly it won't work... (I would normally just keep it in spin, but there is some other tasks I would like to do in assy during the pause between samples). I spent way too much time beating my head against the wall, and I am assuming it is some stupid mistake I made. Thanks in advance for you help.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
TC1_OUT = 14
TC2_OUT = 15
TC_CS = 16
TC_SCK = 17
OBJ
Debug : "FullDuplexSerial"
VAR
Long cog
Long Pins
Long Temperature
Long Stack[noparse][[/noparse]300]
PUB Main
Debug.start(31, 30, 0, 57600)
Start(TC1_OUT, TC2_OUT, TC_CS, TC_SCK)
'cognew(Thermocouple, @Stack)
'waitcnt(clkfreq + cnt)
repeat
'Debug.dec(Temperature >> 3)
'Debug.tx(".")
'Debug.dec(((Temperature >> 1) & %11)*25)
Debug.bin(Temperature[noparse][[/noparse]0], 16)
Debug.tx(13)
waitcnt(clkfreq/2 + cnt)
PUB Thermocouple | a, conv
outA[noparse][[/noparse]TC_CS] := 1
outA[noparse][[/noparse]TC_SCK] := 1
dirA[noparse][[/noparse]TC1_OUT]~
dirA[noparse][[/noparse]TC_CS]~~
dirA[noparse][[/noparse]TC_SCK]~~
repeat
outA[noparse][[/noparse]TC_CS] := 0
conv := 0
repeat a FROM 13 To 0
outA[noparse][[/noparse]TC_SCK] := 0
conv += inA[noparse][[/noparse]TC1_OUT] << a
'Don't care about remaining two bits
Temperature[noparse][[/noparse]0] := conv
PUB Start(T1_OUT, T2_OUT, T_CS, T_SCK)
Pins[noparse][[/noparse]0] := T1_OUT
Pins := T2_OUT
Pins := T_CS
Pins := T_SCK
cog := cognew(@entry, @Temperature) + 1
DAT
org
entry mov tmp1, par 'get Temperature 1 result pointer
mov tmp3, tmp1
or outa, CS_mask 'set CS to high
or outa, SCK_mask 'set SCK to high
andn dira, T1_mask 'set T1 to inputs
or dira, CS_mask 'set CS and SCK to outputs
or dira, SCK_mask
mov wait, cnt
add wait, hundredclk
mov t1scratchpad, #0
mov bitpos, #14
conversion andn outa, CS_mask 'set CS to low
waitcnt wait, hundredclk
mov bitpos, #16
:loop andn outa, SCK_mask 'set SCK to low
test T1_mask, ina wc 'grab bit for T1
rcl t1scratchpad, #1
djnz bitpos, #:loop
wrlong t1scratchpad, tmp3
waitcnt wait, startconv
jmp #conversion
startconv long 20_000_000 'quarter second to start conversion
hundredclk long 10000
T1_mask long |< 14
T2_mask long |< 15
CS_mask long |< 16
SCK_mask long |< 17
tmp1 res 1 'main pointer
tmp2 res 1 'temp pointer
tmp3 res 1 'pointer for temperature 1 result
tmp4 res 1 'pointer for temperature 2 result
t1scratchpad res 1
bitpos res 1
wait res 1
fit
Needs to be after the conversion label so it is reset before being filled up with your 16 bits, otherwise you end up with 32 bits of random stuff.
I also could not see the error so I just set bit 14 high and looked at what it returned, it was FFFFFFFF which suggested the problem.
Graham
DAT org entry mov tmp1, par 'get Temperature 1 result pointer mov tmp3, tmp1 or outa, CS_mask 'set CS to high or outa, SCK_mask 'set SCK to high or dira, CS_mask 'set CS and SCK to outputs or dira, SCK_mask mov overallwait, cnt add overallwait, fifthsec conversion mov wait, cnt add wait, hundredclk mov t1scratchpad, #0 andn outa, CS_mask 'set CS to low waitcnt wait, hundredclk mov bitpos, #14 :loop andn outa, SCK_mask 'set SCK to low waitcnt wait, hundredclk test T1_mask, ina wc 'grab bit for T1 rcl t1scratchpad, #1 or outa, SCK_mask 'set SCK to high waitcnt wait, hundredclk djnz bitpos, #:loop wrlong t1scratchpad, tmp3 or outa, CS_mask 'set CS to high waitcnt overallwait, fifthsec jmp #conversion fifthsec long 20_000_000 'quarter second to start conversion hundredclk long 100 T1_mask long |< 14 T2_mask long |< 15 CS_mask long |< 16 SCK_mask long |< 17 tmp1 res 1 'main pointer tmp2 res 1 'pointer for temperature 1 result tmp3 res 1 'pointer for temperature 2 result tmp4 res 1 'pointer for RPM1 result tmp5 res 1 'pointer for RPM1 result t1scratchpad res 1 bitpos res 1 wait res 1 overallwait res 1 fit
