MAX6675 Assembly code
I am trying to interface with a MAX6675 Thermocouple chip and having some issues. The spin code works fine, but when I try to translate it over to assembly it won't work... (I would normally just keep it in spin, but there is some other tasks I would like to do in assy during the pause between samples). I spent way too much time beating my head against the wall, and I am assuming it is some stupid mistake I made. Thanks in advance for you help.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 TC1_OUT = 14 TC2_OUT = 15 TC_CS = 16 TC_SCK = 17 OBJ Debug : "FullDuplexSerial" VAR Long cog Long Pins Long Temperature Long Stack[noparse][[/noparse]300] PUB Main Debug.start(31, 30, 0, 57600) Start(TC1_OUT, TC2_OUT, TC_CS, TC_SCK) 'cognew(Thermocouple, @Stack) 'waitcnt(clkfreq + cnt) repeat 'Debug.dec(Temperature >> 3) 'Debug.tx(".") 'Debug.dec(((Temperature >> 1) & %11)*25) Debug.bin(Temperature[noparse][[/noparse]0], 16) Debug.tx(13) waitcnt(clkfreq/2 + cnt) PUB Thermocouple | a, conv outA[noparse][[/noparse]TC_CS] := 1 outA[noparse][[/noparse]TC_SCK] := 1 dirA[noparse][[/noparse]TC1_OUT]~ dirA[noparse][[/noparse]TC_CS]~~ dirA[noparse][[/noparse]TC_SCK]~~ repeat outA[noparse][[/noparse]TC_CS] := 0 conv := 0 repeat a FROM 13 To 0 outA[noparse][[/noparse]TC_SCK] := 0 conv += inA[noparse][[/noparse]TC1_OUT] << a outA[noparse][[/noparse]TC_SCK] := 1 'Don't care about remaining two bits outA[noparse][[/noparse]TC_CS] := 1 Temperature[noparse][[/noparse]0] := conv waitcnt(clkfreq/2 + cnt) PUB Start(T1_OUT, T2_OUT, T_CS, T_SCK) Pins[noparse][[/noparse]0] := T1_OUT Pins := T2_OUT Pins := T_CS Pins := T_SCK cog := cognew(@entry, @Temperature) + 1 DAT org entry mov tmp1, par 'get Temperature 1 result pointer mov tmp3, tmp1 or outa, CS_mask 'set CS to high or outa, SCK_mask 'set SCK to high andn dira, T1_mask 'set T1 to inputs or dira, CS_mask 'set CS and SCK to outputs or dira, SCK_mask mov wait, cnt add wait, hundredclk mov t1scratchpad, #0 mov bitpos, #14 conversion andn outa, CS_mask 'set CS to low waitcnt wait, hundredclk mov bitpos, #16 :loop andn outa, SCK_mask 'set SCK to low waitcnt wait, hundredclk test T1_mask, ina wc 'grab bit for T1 rcl t1scratchpad, #1 or outa, SCK_mask 'set SCK to high waitcnt wait, hundredclk djnz bitpos, #:loop wrlong t1scratchpad, tmp3 waitcnt wait, hundredclk or outa, CS_mask 'set CS to high waitcnt wait, startconv jmp #conversion startconv long 20_000_000 'quarter second to start conversion hundredclk long 10000 T1_mask long |< 14 T2_mask long |< 15 CS_mask long |< 16 SCK_mask long |< 17 tmp1 res 1 'main pointer tmp2 res 1 'temp pointer tmp3 res 1 'pointer for temperature 1 result tmp4 res 1 'pointer for temperature 2 result t1scratchpad res 1 bitpos res 1 wait res 1 fit
Needs to be after the conversion label so it is reset before being filled up with your 16 bits, otherwise you end up with 32 bits of random stuff.
I also could not see the error so I just set bit 14 high and looked at what it returned, it was FFFFFFFF which suggested the problem.
Graham
