Bluetooth for the Prop - Some ideas ???
Cluso99
I was pondering the use of a bluetooth mouse for use by the prop to communicate to the PC. Cheap enough I thought and you get both ends, meaning the USB Bluetooth as well.
If speed is not an issue, it would be fairly simple to have the prop use the button interface to send data by smulating buton presses and decoding them at the PC end. Whether I could break into the mouse board further I have not determined.
This led me to check the internet where I found Sparkfun have Bluetooth modules for $35. The PC end USB modules are $11 and here is a link with one taken apart http://www.sparkfun.com/commerce/news.php?id=282
This got me thinking further... I wonder if it is possible to connect the prop to the usb end and simulate a USB master connection. Since we know what we are talking to it may be possible to do this by violating some USB specs in order to make this work.
What would this require...? Two USB modules and a USB connector for the prop end. I already know we can force a USB A connector into a PS2 pcb mounting. A small link is required to join the unused USB pin to the unconnected prop pin on the PS2 connector, so the hardware interface is easy as.
Now comes the hard bit. How do we do the USB software. BradC has done some work here, so maybe Brad you could throw some light on this. Only trying to do a serial interface.
If this could work it would be way cool and cheap.
Leon
Leon Heller
Amateur radio callsign: G1HSM
The modules cost around 12€ and at www.elektor.de there is a complete PCB available, for·27€ ( http://www.elektor.de/products/kits-modules/kits-(-7x)/bluetooth-mit-dem-atm18-(080948-71).1040106.lynkx·) ... unfortunately I can't find it in the english shop.
Post Edited (MagIO2) : 2/23/2010 1:52:26 PM GMT
Someone on these forums recently found a similar module on ebay for $18 but I've lost the link temporarily.
I think if you can get a module which is easy to get working for $18 in serial mode, its a better option than trying to hack a $11 usb slave device (lot of sweat and tears for $7!)
The RN41 and similar modules are larger (about 26 x 13mm), but you could actually lift them off the PCB using short headers, which would free up the underspace for uSD, your SRAM chip, etc. But those usb bluetooth adapters are positively tiny, I have to admit. Wonder if anyone has dissected them to see if there are two chips instead of one (in which case there may be UART style links in between
For true USB host I'm looking at what an LPC2362 would offer for about $5 (Ethernet / USB otg). Futurlec sell an "LPC meal deal" - the big brother (LPC2368) plus a TQFP100 breakout PCB for about $10. Initial goal would just be to get it to behave like a usb prop plug. Plus its good soldering practice for when Prop2 comes in TQFP100
cheers
tubular
My aim is to be able to use existing pcbs with only a minor mod (1 wire link) and substitute the PS2 keyboard/mouse with the USB Bluetooth stick. This is how it would connect...
- Add a wire link on the pcb to connect the kbdata pin to the unused secondary clock pin on the PS2 connector
- Use a PS2 to USB adapter (passive) - used for converting USB keyboards to PS2 connector
- Or.. Replace the PS2 socket with a USB - A connector· minor force required
Here is what I mean... Quick dwg showing the ps2 connector (not the pcb footprint)UPDATE: Would require 2x100R changed to 2x68R and 2x10K pullups removed, and 1x1K5 to a free prop pin to one of the USB pins. However, code is going to be a nightmare! - see a few posts below.
This would be so simple and cheap, and you would have 2 USB Bluetooth adapters for other things uses too
Post Edited (Cluso99) : 2/24/2010 6:07:12 AM GMT
Bluetooth with the PC would be great, but wouldn't implementing an IRDA-like solution be cheaper, if speed is not an issue? It would save trying to interface with USB to get PC to Prop communication going at a relatively low pin count.
Game(s) Mythic Flight
Utilities Font Editors (AIGeneric, Potato_Text, etc.)
However, if we could do it the way I suggested, there are multiple uses for this with existing pcbs. Just use the mouse port on some pcbs as they are often not used.
trodoss: I don't want line of sight.
I'm pretty sure the SparkFun modules are all locked into the serial profile and can't host other devices. I could be wrong though.
A serial Bluetooth module is going to be the solution.
Well, it was a nice idea if it worked [noparse]:([/noparse]
Otherwise, the ZigBee modules look like a good choice.
They are quite cheap.
