CNC Machine using Propellers...
This project, while not a robot, is something I have been working on for a while now.· It is a 3 axes CNC machine capable of performing PCB drilling and isolation milling.· It uses 2 Propeller chips to handle two of the tough tasks: Motion Control and Keyboard, Mouse, and VGA interfacing. It has been a fun project and certainly helped me to learn about the Propeller chips and what they are capable of.
Here are links to some videos about it...
This is an overview of the machine
http://www.youtube.com/watch?v=ybEraG8FeP8
This is an overview of the control
http://www.youtube.com/watch?v=PSuObtH2Tng
This is the machine in action
http://www.youtube.com/watch?v=HF1Z9evXor0
I think I attached a photo to this message as well.
Chris
Chris
So will this become a product?
Cheers,
Graham
I seriously doubt it if I will bring either the machine or the control to market.· Customer support for a CNC control is VERY demanding.· People often need so much help getting going with them, you run at a loss too much of the time.· The machine would probably be too expensive as well to sell.·
The project started out as a test bed to develope the control and the whole purpose of developing the control was to challenge myself - so far I have succeeded :-) ( I learned that I am mentally challenged)
Chris
Keep challenging yourself if this is the result!
Graham
Andrew
I especially like your display with mouse control. What resolution are you using? What object did you use?
Doug
Parallax Forums - If you're ready to learn, we're ready to help.
Yes, that is VGA-HiRes that I am using for the display - rock solid and easy to use.
Chris
