Help identifying and IC chip.
Its a 4 pin surface mount used in a motor for counting rpm.
There is a magnet that spins over the chip each rotation.
Im looking for a wiring or data sheet on how to hook it up.
Or a way to figure out which pins do what.
The only writing in it says 486?
Thanks John
Thanks John
I tried all the example in the Understanding micro controller book for switches but cant get it to work
How would i hook it up to an input
Thanks again
1. Change of the operation magnetic flux density does not depend on the supply voltage, because the stabilization power supply is built-in. (only for the range ;· VCC= 4.5 to 16V)
Electrical Characteristics (Ta=25°C) when I·read the speck what I get out of it that the output has at least 10 millamps
··Thanks for any·
Sam
Also the Vdd and Vss on the homework board is only 5 v is that· to low to power the chip?
thanks
Hook a volt meter to Vss to output and also try ·Vcc to output and see which one changes on some sensor I have seen it where Vcc to output is where you see the change not Vss to output
Are you using a magnet on top of the chip .....>>>> ·try > to the right < >·to left·<> ·to top <> bottom <·· ·as well
··Thanks for any·
Sam
