Help identifying and IC chip.
jdolecki
Its a 4 pin surface mount used in a motor for counting rpm.
There is a magnet that spins over the chip each rotation.
Im looking for a wiring or data sheet on how to hook it up.
Or a way to figure out which pins do what.
The only writing in it says 486?
Thanks John
Thanks John
I tried all the example in the Understanding micro controller book for switches but cant get it to work
How would i hook it up to an input
Thanks again
1. Change of the operation magnetic flux density does not depend on the supply voltage, because the stabilization power supply is built-in. (only for the range ;· VCC= 4.5 to 16V)
Electrical Characteristics (Ta=25°C) when I·read the speck what I get out of it that the output has at least 10 millamps
··Thanks for any··that you may have and all of your time finding them
Sam
Also the Vdd and Vss on the homework board is only 5 v is that· to low to power the chip?
thanks
Hook a volt meter to Vss to output and also try ·Vcc to output and see which one changes on some sensor I have seen it where Vcc to output is where you see the change not Vss to output
Are you using a magnet on top of the chip .....>>>> ·try > to the right < >·to left·<> ·to top <> bottom <·· ·as well
Sam
