Moving toward N64 controllers?
Oldbitcollector (Jeff)
I'm thinking that it is past time for a move toward N64 controllers over the NES stuff.
Has anyone got an leads on N64 female connectors? The objects are certainly ready.
Thoughts?
OBC
New to the Propeller?
Thoughts?
OBC
Wouldn't the Wii Nunchuck be a logical next step? There was an object (in the OBEX?) for that as well.
Game(s) Mythic Flight
Utilities Font Editors (AIGeneric, Potato_Text, etc.)
I've asked KenG about the possibility of sourcing some N64 connectors like he did with the NES.
The attraction is the bang for the single pin count.
You're right, I should take a second look at the Wii stuff.
OBC
I mention it because it is more "modern," and there is a PCB available at SparkFun or FunGizmos ("WiiChuck Adapter"). Most likely the same design could be incorporated into other PCB's as well.
You can go into the local gaming or retail store and buy a Wii Nunchuck. The N64, you don't necessarily have that option.
That would be an interesting upgrade.
OBC
We bump back into the problem of connectors again..
Maybe it's also time to write a unversal controller driver.... [noparse]:)[/noparse]
OBC
I could do something like the nunchucky (here), combined with video / audio and SD.
Downside is the cable is pretty short, maybe 3 feet.
Classic controllers aren't everywhere, but they're probably easier to get than an N64 controller. Also, the classic controller is better than N64.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
