Sensirion Humidity Sensor Question — Parallax Forums
Sal AmmoniacSal Ammoniac Posts: 213
edited 2010-02-18 20:04 in Accessories
I've added a Sensirion humidity sensor to my weather station and frequently see humidity readings over 100% in the early mornings. It often goes as high as 106%.
When this occurs do I need to turn on the sensor's built-in heater until the humidity reading drops below 100%? Does a reading >100% indicate condensation on the sensor that can affect future readings?
    edited 2010-02-17 22:07
    ·I would thing There is problem because real early in the morning that why you see due all over the place and that when you have over 100% humidity
    It would not hurt to turn on the heater for a short time· but even then it may still read over 100 % when the sensor cool back down
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    edited 2010-02-18 04:16
    Hi Sal Ammoniac,
    The accuracy of the sensor falls off at high humidity, +/-5% at 100% for the SHT11 according to the attached graph from the Sensirion documentation.
    Are you using the recommended linearity and temperature compensation formulas?
    I don't think the internal heater is going to help. It may have something to do with how the sensor is situated. The best location is inside a weather shelter or radiation shield or in the shelter of a tree, where it is shielded from radiation from the cold sky or from the ground.
    Tracy Allen
    www.emesystems.com
    318 x 174 - 65K
    edited 2010-02-18 05:41
    I'll second what Tracy posted and add one question:
    1) Is your code optimized for teh voltage you are supplying the sensor?
    Andrew Williams
    WBA Consulting
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    Propeller-Based Reverse Geo-Cache Birthday Present Project
  • Sal AmmoniacSal Ammoniac Posts: 213
    Tracy:
    Yes, I am using the recommended linearity and temperature compensation formulas from the datasheet. I have the Sensirion sensor mounted in a small plastic box about 2" x 1" x 1". I've drilled a grid of 1/8" holes in the metal cover of the box to admit ambient air. The box containing the sensor is mounted with the holes facing down in a standard cotton region wooden instrument shelter.
    Andrew:
    Yes, I am using 3.5v coefficients from the datasheet (I'm running the sensor at 3.3v and the 3.5v coefficients are the closest to that value).
