Sensirion Humidity Sensor Question
I've added a Sensirion humidity sensor to my weather station and frequently see humidity readings over 100% in the early mornings. It often goes as high as 106%.
When this occurs do I need to turn on the sensor's built-in heater until the humidity reading drops below 100%? Does a reading >100% indicate condensation on the sensor that can affect future readings?
It would not hurt to turn on the heater for a short time· but even then it may still read over 100 % when the sensor cool back down
··Thanks for any·
Sam
The accuracy of the sensor falls off at high humidity, +/-5% at 100% for the SHT11 according to the attached graph from the Sensirion documentation.
Are you using the recommended linearity and temperature compensation formulas?
I don't think the internal heater is going to help. It may have something to do with how the sensor is situated. The best location is inside a weather shelter or radiation shield or in the shelter of a tree, where it is shielded from radiation from the cold sky or from the ground.
Tracy Allen
www.emesystems.com
1) Is your code optimized for teh voltage you are supplying the sensor?
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
Yes, I am using the recommended linearity and temperature compensation formulas from the datasheet. I have the Sensirion sensor mounted in a small plastic box about 2" x 1" x 1". I've drilled a grid of 1/8" holes in the metal cover of the box to admit ambient air. The box containing the sensor is mounted with the holes facing down in a standard cotton region wooden instrument shelter.
Andrew:
Yes, I am using 3.5v coefficients from the datasheet (I'm running the sensor at 3.3v and the 3.5v coefficients are the closest to that value).
