Anyone have a favorite and simple power supply design for 24 - 50 volts dc to 5
Looking for a simple (read low parts count) and compact design. Only needs to be capable of approx 1 amp max or less. I have looked at several switching type regulators but the stumbling block seems to be the upper input voltage limit (50v).
Leon
Amateur radio callsign: G1HSM
http://www.robotmarketplace.com/products/motors_main.html
and the voltage regulator of your choice. The simple circuit would convert 50VDC to 12VDC and is a step-down
multivibrator inverter, (the step up from battery to AC outlet version invented probably around 1960).
The coil is probably somewhat critical; if it has too little inductance then the transistors will lose their
magic smoke. The coil may be replaced by a 120 to 24 VAC transformer center-tapped on both sides,
but a coil able to oscillate at much higher frequency than 60Hz is lighter and more efficient.
This has not been tested. It should be tested at 50 V in series with a 40 watt light bulb, which limits the
current and should not light up except dimly when the output is intentionally shorted as a transistor heat test.
2N3055s may work. Resistors may be necessary as the base to collector cross-connections.
Use 2N2955s and reverse input polarity if you must have common negative ground,
or otherwise use a dual winding center-tapped transformer instead of a coil.
This is an experimental untested design, based very old technology,
and may not work as-is without some additional parts and careful adjustment.
I designed it spontaneously and would not expect it to work on the first try.
I do not recommend buying new parts for testing this design. Other power transistors can be tried.
Note that it is similar to a simple inverter circuit called "Joule Thief" but is being used in step-down mode.
The schematic is ascii because I do not have Propeller Font on this computer.
I should be typing in Spin now.
Coming soon. My open Propeller Project Pages and favorite links index.
