Parallex USB Servo Controller not recognised
Hello,
Today I got my new Parallex USB Servo Controller, after downloading and installing the drivers i connected the card to the PC and saw the led's on the board light up. I then tried running PSCi, went to file and selected COM4 (only available) and connected. The status is green with "Comm Port Open", I then tried file -> Get PSC version but this returns PSC not found, although if I move the sliders of a channel I do see the led's blink (2 larger ones near the usb connector and a small red one near the chip). The servo's also don't seem to respond (Parallex servo's).
What could be the problem?
What happens when you load the Propeller IDE and try to identify the Propeller by pressing F7?
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/26/2010 8:29:34 PM GMT
Edwin
That sounds like where your problem is. If the IDE tool can't see it, then nothing else would be able to either.
What does your power supply to the Parallax USB Servo Controller look like?
Would it be possible to take any clear pictures and or schematic of your setup and post them?
Beau Schwabe
IC Layout Engineer
