FORTH based Propeller assember for PropellerForth — Parallax Forums
BazmundiBazmundi Posts: 3
edited 2010-02-16 03:59 in Propeller 1
Hey team,
I am a FORTH nut from way back and have had my interest rekindled because of the propeller chip and propelerForth.
It doesn't appear to have an assembler.
No problem, one of my favourite passtimes was writing assemblers in Forth.
Problem is I have found a piece of information on the bit fields for op codes used in the propeller but not the bit field contents and how they relate to op codes.
Has anyone got a table of propeller op codes and their bit field values?
Cheers,
Baz
  • BazmundiBazmundi Posts: 3
    edited 2010-02-10 22:06
    DOH! Never mind.· RTFM.· Found the info.
  • hinvhinv Posts: 1,272
    edited 2010-02-15 22:01
    I would be glad to see a forth compiler as well, run directly on the propeller. Now that would be cool.
    edited 2010-02-16 00:13
    Seems like Forth would be a natural fit for LMM inline assembly along with a pure PASM kernal.
    edited 2010-02-16 00:17
    hinv said...
    When I was a Propeller newbie I had a go at writing a Forth for it. It didn't look pretty. Recently I revisited the Forth compiler as I had been doing some work with an ARM Forth that I had written a few years ago and I really wanted this kind of functionality with the Prop. On the ARM system I could hook up a keyboard and a monitor and access the SD card so it was a complete O/S as well, all with a CPU that costs the same as the Prop.
    Sp using my honed PASM skills I tried a few different angles, even reading 4 byte tokens per long to keep the hub overhead down and keeping track of it all. Everything I tried so far shows up the inadequacies of the Prop architecture for a truly efficient Prop Forth. The best I think I could manage would be around 1 to 2 million Forth instructions per second. Ok, that's faster than Spin maybe but it felt kludgey. The hub access really slows things down but even the address interpreter takes way too many cycles. In ARM this is what it looks like:
    NextIP:
        ldrb    r1,[noparse][[/noparse]IP],#1                ; read the next byte TOKEN
        mov    r0,#TOKENS        ; create aligned pointer to token lookup table
        ldr    pc,[noparse][[/noparse]r0,r1,lsl #2]            ; execute token code
    Bear in mind I was running the ARM at 66MHz which meant that each instruction took around 15ns so the whole address interpreter executes faster than a single PASM instruction. But what about the primitives, take the SWAP instruction for instance, here it is in ARM:
    H$ "SWAP"    ,( n1 n2 -- n2 n1)
        ASMCODE    _SWAP
        ldr    sec,[noparse][[/noparse]PSP,#SEC]        ; Get 2nd item
        str    tos,[noparse][[/noparse]PSP,#SEC]        ; save tos into 2nd
        str    sec,[noparse][[/noparse]PSP,#TOS]        ; save 2nd into tos
        mov    tos,sec
        NEXT
    Compare this with a good Propeller Forth "PropForth" by Sal Sanci:
    a_swap
                            call    #a_stpoptreg
                            mov     treg2, stTOS
                            mov     stTOS, treg1
                            call    #a_stPush
                            mov     stTOS, treg2
                            jmp     #a_next
    That doesn't look too bad although each instruction is much slower than ARM and there are more instructions including the subroutines. How about those subroutines then?
    a_stpoptreg      mov     treg1, stTOS
    a_stPop   if_never      jmpret a_stPop_ret, # a_stPop_ret        ' when task manager is loaded these addresses wil be patched
                            add     stPtr, #1
                            movs    a_stPop1, stPtr
                            cmp     stPtr, #stTop           wc,wz
                  if_ae     jmp     # a_reset
    a_stPop1                mov     stTOS, stPtr
    a_stPop_ret
    a_stpoptreg_ret         ret
    My new version in PASM looks very efficient (used a simple PLUS primitive rather than my incomplete SWAP):
    :addt   movd  :addt1,sp         ' create destination field (TOS)
            add   sp,#2             ' pop and point to second stack item (ascending stack)
            movs  :addt1,sp         ' create source field
            nop                     ' wait
    :addt1  add   0_0,0_0           ' add source to destination
            ret                     ' return to address interpreter (or caller)
            res       2             ' alll kernel primitves are multiples of 8 longs for fast direct token indexing
    But all this is further let down by the limited assembler code that can be run in a cog, except for a handful of primitives the rest of the kernel has to be coded in high level tokens which are already slow.
    My feeling is that the best Forth that can be implemented on the Propeller would still be a crippled Forth as well as hog resources and not leave room for much else. This is also a reason I advocate using a cheap ARM chip alongside the Propeller as Co-processors together. Let the Prop do what it does best as it is an I/O wizard but still a microcontroller.
    *Peter*
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2010-02-16 00:23
    Peter Jakacki said...
    While everyone else is flashing LEDs [noparse]:)[/noparse]
    edited 2010-02-16 02:23
    Graham said...
    Even I was doing more advanced things back then. I was flashing the LED's backwards,. lol.gif
    @Peter
    I always enjoy reading your posts and have learn plenty from your efforts. Thanks!
    Bob said...
    That's better than my advanced efforts now.
    The best I can do is flash the LED's upside down. [noparse];)[/noparse]
    Maybe we'll see some additional FORTH development.
    We should encourage Peter to pick up work again on his version.
    He has a brilliant mind when occupied by projects like this!
