DIY Linear Scale
Brian_B
·Last week I completed a shop press that I have been working on for awhile.On of the reasons I built it was so I could use it as a press brake, or better yet a CNC press brake (propeller power a must). I am to tight to run out and buy a linear scale so I dug out a bunch of stuff and made my own.
·I used a HEDS encoder and a rack and pinion drive system to measure movement·. I tested it out and have a 1000 counts per inch from the encoder ,the next step is to wire every thing up and see how it works.
·If everything works out, someday I'll be able to control everything in my shop from the house
Brian
"Imagination is more important than knowledge..." Albert Einstein
Brian
Brian
John R.
Click here to see my Nomad Build Log
·I installed a prox. home switch on the up stroke·and zero the count every time it see's it (ever cycle). It brought it down to +/- .011 . I set the·downward stroke to·3000 counts and it seems to jump around a little bit on the stop . 2990 ,3005, 3013,2998 ,2985 ,3003, ect.
Brian
Edit: Here is the Propeller code If anyone is interested ,It's not pretty and I'm just using it to test. It·goes to show you·almost anyone can program the propeller
Post Edited (Brian_B) : 2/11/2010 4:55:33 AM GMT
