HMC6352 compass issues
·I have the honeywell HMC6352 I2C compass.· I'm having problems with the directions, ie· from north shows 276, south show 232 west about 250 and east 55.· I'm not concerned about norht not showing 0, since thats more an issue of how it's mounted,· but more concerned about the scale of north-west-south is·44 degrees, and north-east-south·316 degrees.
I can live with some of the hobby-compass issues,· but would like north-south to be somewhat close to 180 apart, same with east-west.
I tried the compass with by BS2 and the propeller, same results, even after several calibrations.
I'm using the standard code provided on the parallax website.
Anybody else have similar problems ?·· Maybe I need to switch to the hitachi HM55B ?·
Dave
Dave Andreae
Parallax Tech Support·
Also,· I could not get the compass to work with the voltage translaters on the MSR1, so I disabled one of them, also, to 80MHz, it would·give garbage readings,·so I added a slight pause to the code, to give the compass time, and that seemed to work. But still readings are·way off.
Dave·
Dave Andreae
