Multiplexing Bulbs on Nixie Clock
So I built myself a nixie clock using the Basic Stamp 2 as the brains.
I used a multiplexed design... Only one bulb is on at a time. The code cycles through the six bulbs sending the correct digit for each bulb. Unfortunatly, my code runs too slow causing the bulbs to flicker. I was hoping someone might be able to point out how I might make the code more efficient. Do I need to use binary code to send the pin states? (%001001 or something?).
Youtube clip of the clock:
www.youtube.com/watch?v=FNFPThBWOUU
Here is the portion of code in question:
' MAIN LOOP ------------------------
main:
FOR bulb = 0 TO 5
ON bulb GOSUB bulb_1, bulb_2, bulb_3, bulb_4, bulb_5, bulb_6
NEXT
GOSUB ReadRTCBurst
GOTO main
'reads time from clock chip
ReadRTCBurst:
HIGH RTCReset
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours]
LOW RTCReset
RETURN
'---------------BULB WRITING SUBROUTINES BELOW ------------------
bulb_1:
LOW 7
digit = hours.HIGHNIB
ON digit GOSUB digit_0, digit_1, digit_2
HIGH 2
RETURN
bulb_2:
LOW 2
digit = hours.LOWNIB
ON digit GOSUB digit_0, digit_1, digit_2, digit_3, digit_4, digit_5, digit_6, digit_7, digit_8, digit_9
HIGH 3
RETURN
bulb_3:
LOW 3
digit = minutes.HIGHNIB
HIGH 4
RETURN
bulb_4:
LOW 4
digit = minutes.LOWNIB
HIGH 5
RETURN
bulb_5:
LOW 5
digit = seconds.HIGHNIB
HIGH 6
RETURN
bulb_6:
LOW 6
digit = seconds.LOWNIB
HIGH 7
RETURN
digit_0:
LOW 11
LOW 12
LOW 13
LOW 14
RETURN
digit_1:
LOW 11
LOW 12
LOW 13
HIGH 14
RETURN
digit_2:
LOW 11
LOW 12
HIGH 13
LOW 14
RETURN
digit_3:
LOW 11
LOW 12
HIGH 13
HIGH 14
RETURN
digit_4:
LOW 11
HIGH 12
LOW 13
LOW 14
RETURN
digit_5:
LOW 11
HIGH 12
LOW 13
HIGH 14
RETURN
digit_6:
LOW 11
HIGH 12
HIGH 13
LOW 14
RETURN
digit_7:
LOW 11
HIGH 12
HIGH 13
HIGH 14
RETURN
digit_8:
HIGH 11
LOW 12
LOW 13
LOW 14
RETURN
digit_9:
HIGH 11
LOW 12
LOW 13
HIGH 14
RETURN[url=http://][/url][url=http://][/url][url=http://][/url][url=http://][/url]
Have You tried putting;
"ReadRTCBurst:
......HIGH RTCReset
......SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
......SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours]
......LOW RTCReset "
In the Main: loop with out a gosub?
This has worked for Me using seven seg. led displays
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
'define digit constants d0 CON %0000 d1 CON %0001 d2 CON %0010 d3 CON %0011 d4 CON %0100 d5 CON %0101 d6 CON %0110 d7 CON %0111 d8 CON %1000 d9 CON %1001 'define bulb constants bulb1 CON %000001 bulb2 CON %000010 bulb3 CON %000100 bulb4 CON %001000 bulb5 CON %010000 bulb6 CON %100000 DIRH = %11111111 DIRL = %11111111 ' MAIN LOOP ------------------------ main: FOR bulb = 0 TO 5 ON bulb GOSUB bulb_1, bulb_2, bulb_3, bulb_4, bulb_5, bulb_6 NEXT 'read time from chip HIGH RTCReset SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2] SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours] LOW RTCReset GOTO main ' ---------------------------------- '---------------BULB WRITING SUBROUTINES BELOW ------------------ bulb_1: OUTH = %000000 digit = hours.HIGHNIB LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL OUTH = %000001 RETURN bulb_2: digit = hours.LOWNIB OUTH = %000000 LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL OUTH = %000010 RETURN bulb_3: digit = minutes.HIGHNIB OUTH = %000000 LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL OUTH = %000100 RETURN bulb_4: digit = minutes.LOWNIB OUTH = %000000 LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL OUTH = %001000 RETURN bulb_5: digit = seconds.HIGHNIB OUTH = %000000 LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL OUTH = %010000 RETURN bulb_6: digit = seconds.LOWNIB OUTH = %000000 LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL OUTH = %100000 RETURNPost Edited (sbelsky) : 2/7/2010 4:45:57 AM GMT
