Multiplexing Bulbs on Nixie Clock — Parallax Forums
sbelskysbelsky Posts: 3
edited 2010-02-09 01:48 in BASIC Stamp
So I built myself a nixie clock using the Basic Stamp 2 as the brains.
I used a multiplexed design... Only one bulb is on at a time. The code cycles through the six bulbs sending the correct digit for each bulb. Unfortunatly, my code runs too slow causing the bulbs to flicker. I was hoping someone might be able to point out how I might make the code more efficient. Do I need to use binary code to send the pin states? (%001001 or something?).
Youtube clip of the clock:
www.youtube.com/watch?v=FNFPThBWOUU
Here is the portion of code in question:
' MAIN LOOP ------------------------
main:
  FOR bulb = 0 TO 5
    ON bulb GOSUB bulb_1, bulb_2, bulb_3, bulb_4, bulb_5, bulb_6
  NEXT
  GOSUB ReadRTCBurst
GOTO main
'reads time from clock chip
ReadRTCBurst:
  HIGH RTCReset
  SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
  SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours]
  LOW RTCReset
RETURN
'---------------BULB WRITING SUBROUTINES BELOW ------------------
bulb_1:
  LOW 7
  digit = hours.HIGHNIB
  ON digit GOSUB digit_0, digit_1, digit_2
  HIGH 2
RETURN
bulb_2:
  LOW 2
  digit = hours.LOWNIB
  ON digit GOSUB digit_0, digit_1, digit_2, digit_3, digit_4, digit_5, digit_6, digit_7, digit_8, digit_9
  HIGH 3
RETURN
bulb_3:
  LOW 3
  digit = minutes.HIGHNIB
  HIGH 4
RETURN
bulb_4:
  LOW 4
  digit = minutes.LOWNIB
  HIGH 5
RETURN
bulb_5:
  LOW 5
  digit = seconds.HIGHNIB
  HIGH 6
RETURN
bulb_6:
  LOW 6
  digit = seconds.LOWNIB
  HIGH 7
RETURN
  digit_0:
  LOW 11
  LOW 12
  LOW 13
  LOW 14
  RETURN
  digit_1:
  LOW 11
  LOW 12
  LOW 13
  HIGH 14
  RETURN
  digit_2:
  LOW 11
  LOW 12
  HIGH 13
  LOW 14
  RETURN
  digit_3:
  LOW 11
  LOW 12
  HIGH 13
  HIGH 14
  RETURN
  digit_4:
  LOW 11
  HIGH 12
  LOW 13
  LOW 14
  RETURN
  digit_5:
  LOW 11
  HIGH 12
  LOW 13
  HIGH 14
  RETURN
  digit_6:
  LOW  11
  HIGH 12
  HIGH 13
  LOW 14
  RETURN
  digit_7:
  LOW 11
  HIGH 12
  HIGH 13
  HIGH 14
  RETURN
  digit_8:
  HIGH 11
  LOW 12
  LOW 13
  LOW 14
  RETURN
  digit_9:
  HIGH 11
  LOW 12
  LOW 13
  HIGH 14
  RETURN[url=http://][/url][url=http://][/url][url=http://][/url][url=http://][/url]
  • $WMc%$WMc% Posts: 1,884
    edited 2010-02-07 02:51
    sbelsky
    Have You tried putting;
    "ReadRTCBurst:
    ......HIGH RTCReset
    ......SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
    ......SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours]
    ......LOW RTCReset "
    In the Main: loop with out a gosub?
    This has worked for Me using seven seg. led displays
    The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
  • sbelskysbelsky Posts: 3
    edited 2010-02-07 04:39
    I've made some changes that improved it slightly but it still runs too slow (note: i changed some pins around as well)...
    'define digit constants
    d0        CON    %0000
    d1        CON    %0001
    d2        CON    %0010
    d3        CON    %0011
    d4        CON    %0100
    d5        CON    %0101
    d6        CON    %0110
    d7        CON    %0111
    d8        CON    %1000
    d9        CON    %1001
    'define bulb constants
    bulb1     CON    %000001
    bulb2     CON    %000010
    bulb3     CON    %000100
    bulb4     CON    %001000
    bulb5     CON    %010000
    bulb6     CON    %100000
    DIRH = %11111111
    DIRL = %11111111
    main:
      FOR bulb = 0 TO 5
      NEXT
      'read time from chip
      HIGH RTCReset
      LOW RTCReset
    GOTO main
    bulb_1:
      OUTH = %000000
      LOOKUP digit, [noparse][[/noparse]d0,d1,d2,d3,d4,d5,d6,d7,d8,d9], OUTL
      OUTH = %000001
    RETURN
    bulb_2:
      OUTH = %000000
      OUTH = %000010
    RETURN
    bulb_3:
      OUTH = %000000
      OUTH = %000100
    RETURN
    bulb_4:
      OUTH = %000000
      OUTH = %001000
    RETURN
    bulb_5:
      OUTH = %000000
      OUTH = %010000
    RETURN
    bulb_6:
      OUTH = %000000
      OUTH = %100000
    RETURN
    Post Edited (sbelsky) : 2/7/2010 4:45:57 AM GMT
    Does anyone see a way to speed this up? Is the BS2 just too slow of a chip?
