future propeller chips - Page 3 — Parallax Forums
13567
  • RossHRossH Posts: 5,694
    edited 2010-02-08 05:38
    hinv,
    Much as I drool (not a pretty sight!) at the though of the Prop II, I agree with you completely - many of the projects being built around the Prop I right now would benefit enormously from a PortB Prop. Some of the emulation and XMM projects would benefit even if Parallax just implemented Port B internally but did not make all the pins accessible externally. Imagine what we could do with superfast cog-to-cog parallel comms that did not consume any I/O pins!
    Ross.
    edited 2010-02-08 06:40
    PropII is shaping up now to have 64 I/O's, not the 96+ as previously stated. The reason has to do with packaging constraints. We met with our packager in Taiwan a few weeks ago about this matter, and what we wanted to do was, in simplistic terms, "very difficult". The problem was not so much technical as it was economic. We would need a special lead-frame·and maybe even·new injection molds to accommodate them. The tooling costs would be quite high to get that going. Even if we paid the tooling costs, I sensed they were somewhat loathe to run it because it would mean changing tooling out on their molding machine when they'd run our stuff, as opposed to leaving the standard tooling in place, and not worrying about QC problems due to switchovers. They strongly recommended that we fall back to one of their standard packages, so we cut down the lead count down·to 100 and went with a larger pitch. This will make things a little easier for some customers and keep us from becoming a pain in·our packager's·neck. They are very volume-oriented and have always given us excellent pricing, even though we are a peon among their other customers.
    Also, the I/O pin circuits have become so large that fitting much more than 16 per die edge would have made the die huge. Now, Beau is rearranging the I/O pin layout so that it is wider than it is tall. This will let us squish them out sideways so that interior core area is freed up. This means more room for RAM.
    While 96+ I/O's would have been quite rich, I feel we are on a better completion path with just 64. I'm getting kind of punch drunk and need to see some light at the end of the tunnel, anyway. Currently, things are feeling quite "right", as opposed to overwhelming.
    Chip Gracey
    Post Edited (Chip Gracey (Parallax)) : 2/8/2010 6:54:49 AM GMT
  • heaterheater Posts: 3,370
    edited 2010-02-08 06:59
    Re: Multi-thread determinism: If a processor has a set of registers for two or more threads. And if each instruction takes the same amount of time, say four clocks. And if that processor executes an instruction from each thread before returning to the first, round robin style. Then the execution of the whole system of thread is as deterministic as having 4 processors running off the same clock at half the speed, or quarter speed or whatever.
    There are two reasons why the XMOS threads fail to be as deterministic as the Propeller COGs.
    1) Adding a second thread to a one thread set up halves the speed of the first thread. Has too. Same if you add a thread to two thread system. So unlike the Prop adding another object into your system can change the timing of the existing parts of the system.
    2) Turns out XMOS divide instructions take longer to execute than other instructions. This means that if one thread suddenly decides to do a divide it will bugger up the timing of any other threads running.
    I had a little debate about determinism with David May the CTO of XMOS over the Christmas break where he had to admit: "So - there is potential interference between divide instructions in different threads"
    So that's it for determinism on XMOS. You cannot do it by simple cycle counting of instructions.
    What you are supposed to do is make proper use of the various timing features of the device. Use the clocked I/O itc.
    In this way multiple threads can exist with totally deterministic timing in a single core.
    It is somewhat harder than just throwing objects at COGs.
    edited 2010-02-08 07:30
    @Chip: Thanks for the update. We can of course live with 64 I/Os. 100 pin package with greater pin spacing is good. Are you still implementing a ground plane connection on the underside of the IC?
    More RAM jumpin.gif· I presume this is hub Ram.
    Are you still implementing the extra port(s)·internally so we could do·32bit cog to cog mailbox/comms or whatever?
    Is the design now frozen? Can you release any other info pls?
    Do you have a timeframe estimate to first silicon yet?
    @hinv: Like many others, I see that the choice of not asking for the Prop IB was a mistake. At the time, although many recognised that we wanted more ram, so much development has occurred since then making a lot more programs require more pins & external SRAM.
    Anyway, I guess it's too late now, although I do see that it would still have it's own market, particularly from a power standpoint. It could be incorporated back into the 40/44 pin packages so that we could access the extra port internally. Unfortunately, we have ignored the Port B access method, so some software would now break with the implementation of Port B.
  • TonyDTonyD Posts: 210
    edited 2010-02-08 10:13
    Roy Eltham said...
    TonyD,
    Sorry for my mistake. It was really hard to tell with the low quality video, and I was going by the text in the blog that just said something like "I had the DAC hooked up backwards" which led me to believe it was a DAC chip. In any case the video shows what looks like a lot more than 8 resisters and a VGA port hooked up to the xmos board (which I looked up on their site as being $149, and the cheapest one they had was $99).
    No problem. Yvo (who wrote the video driver) wired the port signals back to front, so the colours came out all wrong smile.gif
    The DAC was a 15-bit R-2R so used 30 resistors and gave us 32K colours. The board we used was the Ethernet enabled board which cost $150, there are cheaper boards out there Sparkfun have one at $50 but you need a JTAG interface which costs $50.
    Getting back to the thread. As Cluso99 said, if we only getting 64-pins will we still have the ground pad/paddle under the chip? I hope we lose it as it will make hand soldering a lot easier.
    - Tony
    http://zuzebox.wordpress.com/
    Post Edited (TonyD) : 2/8/2010 11:18:32 AM GMT
  • dMajodMajo Posts: 862
    edited 2010-02-08 10:32
    I am 100% with Cluso99.
    There are many ways IO can be expanded, is better to have more ram.
    The internal-use-only extra port will be fantastic !!! This will allow inter-cog comunications without hub access and thus faster, but what is more important without loosing (gained) sync with external environment.
    · Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
  • hinvhinv Posts: 1,256
    edited 2010-02-08 16:00
    @TonyD: I've not done it, but from what I have watched on a youtube video somewhere as long as you have 2 holes under the big ground pad, is not a big deal. You would need one hole to stick your wet solder iron in, and another one to add some solder.
    @dMajo, Chip, Beau: I didn't see them commit to the internal portC, but I sure would like to see it. It go a long way to appeasing those who wanted more bandwidth to certain cogs.
    Oh, and while you're at it. I would like to see P0 on a corner and exactly 16 I/Os per side(if 64I/Os total), and cheap stickers offered with each and every prop (on the same web oder page for like $.10).
    Post Edited (hinv) : 2/8/2010 4:05:43 PM GMT
  • LeonLeon Posts: 7,620
    edited 2010-02-08 16:09
    That's how I solder the pad on a QFN. I only use one large via, though. I only do that for prototypes, of course; production boards are done properly and need a gridded stencil to prevent the chip floating when it is reflowed.
    Leon
    Amateur radio callsign: G1HSM
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2010-02-08 16:37
    @hinv:
    Here is the current 100 pin package outline ... as far as your internal PortC question since there are 64 I/O's technically there are external Ports A,B,C, and D. The internal Port assignment I'll leave for Chip to answer, but I'm almost sure this will be implemented.
    Beau Schwabe
    IC Layout Engineer
    847 x 743 - 192K
  • SapiehaSapieha Posts: 2,964
    edited 2010-02-08 17:21
    Hi Beau Schwabe (Parallax)
    Nice footprint to PropII but that give P31, P32 bad place that can be big problems for XI, XO if P31, P32 is used in high frequncy modes.
    In that case can give Xi, XO posibilites to transcients from P31, P32.
    Look on my reedited picture it is placements of pins I see more reliable for high reliablity for XI, XO.
    Regards
    Christoffer J
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    847 x 743 - 121K
    edited 2010-02-08 17:27
    Beau,
    What are VP0-7 and GP0-7?
    Check out the Propeller Wiki·and contribute if you can.
    edited 2010-02-08 17:32
    Thanks for the update Chip.
    One observation:
    "this means more room for ram" - I am officially drooling. You were already going to have 384KB... 512KB would be insanely great [noparse]:)[/noparse]
    A few questions...
    - On 100 pin TQFP, a lot more than 64 I/O's would be possible... are you considering perhaps 2x32 pin ports, and a 1x16 bit port for SPI, I2C etc?
    - If it is 2x32 and 1x16 (which makes sense on a TQFP-100) could the other 16 bits be implemented internally? It would be great for cog-cog flags
    - If there will only be 64 I/O's on the silicon, could you please look into a PLCC84 package? It would make prototyping MUCH easier, and through-hole PLCC84 sockets are readily available, allowing for through-hole designs
    - If there are only 64 I/O's, I'd strongly prefer going back to the existing PORTA / PORTB mapping in Cog memory, as it would not require switching a port index to update ports, speeding up external memory solutions
    Chip Gracey (Parallax) said...
    PropII is shaping up now to have 64 I/O's, not the 96+ as previously stated. The reason has to do with packaging constraints. We met with our packager in Taiwan a few weeks ago about this matter, and what we wanted to do was, in simplistic terms, "very difficult". The problem was not so much technical as it was economic. We would need a special lead-frame and maybe even new injection molds to accommodate them. The tooling costs would be quite high to get that going. Even if we paid the tooling costs, I sensed they were somewhat loathe to run it because it would mean changing tooling out on their molding machine when they'd run our stuff, as opposed to leaving the standard tooling in place, and not worrying about QC problems due to switchovers. They strongly recommended that we fall back to one of their standard packages, so we cut down the lead count down to 100 and went with a larger pitch. This will make things a little easier for some customers and keep us from becoming a pain in our packager's neck. They are very volume-oriented and have always given us excellent pricing, even though we are a peon among their other customers.
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-02-08 17:35
    I'm creating a PCB part for it (Pulsonix). I've got a spreadsheet with the signals and pin numbers that I can just paste into the part editor. I'll make it available if anyone else wants it.
    [noparse][[/noparse]edit]
    Here it is: www.leonheller.com/Propeller/Propeller%20II%20pinout.xls
    Please let me know if you see any mistakes.
    Leon
    Post Edited (Leon) : 2/8/2010 6:01:44 PM GMT
    edited 2010-02-08 17:39
    Very nice! I like the crystal on the corner as it will be easier to keep the trace lengths the same, and not get in the way of the other I/Os.
    So is TurboProp the official name, or has "marketing" not decided yet?
    edited 2010-02-08 18:27
    Roy: I am presuming that the VP0-7 and GP0-7 are the power and grounds to each bank of I/O pins (a bank is 8 pins) as per chips previous info that each group of I/Os will have seperate power so they can have different voltages.
    Bill: There are 16 power & ground pins and 16 I/O power & ground pins = 32, 2 xtal + reset + BOE = 4, 64 I/O = 64, totalling 100 pins.
    edited 2010-02-08 18:46
    Ah! Ok, now VP0-7 and GP0-7 make sense. Thanks.
    Cluso99 said...
    edited 2010-02-08 18:47
    Cluso99,
    Ah, thanks. That makes sense now, as I recall from earlier postings, the I/Os run at 3.3v and the chip itself runs at 1.8v. So, they need separate power/ground for the I/Os.
    edited 2010-02-08 19:15
    Actually, the I/Os can run at 1.8V, 3.3V, or anything in-between, if I understand correctly. Can someone clarify this? I would, but my search capability went away.
    Anybody that has done chip development want to throw out a guess as to when the TurboProp could go into production considering they layout they are doing now? Maybe I will hold off my purchase of an IGEPv2.
    Doug
    edited 2010-02-08 19:36
    Along with Bill, I would dearly love a PLCC84 version.
    Style and grace : Nil point
  • BigFootBigFoot Posts: 259
    edited 2010-02-08 19:50
    The 100 Pin QPFP would be great for higher volume production. It is a very easy package to
    work with and has been around for awhile.
    Is there still a DAC & ADC on each I/O pin, this seems like kinda a waste of space to me.
    Russ
    edited 2010-02-08 19:51
    @hinv:
    For the power, that is correct. As for the naming, I've learned not to question some of the names that Chip gives to the layout blocks. smilewinkgrin.gif And to your other question "Anybody that has done chip development want to throw out a guess as to when the TurboProp could go into production..." ... sorry to be so vague, but anyone who has done chip development would know better than to answer this question. The development process is always in constant flux with many implementations coming from suggestions here in the forum. We do listen very carefully to ALL of your needs and suggestions and try to accommodate to the best of our ability what will physically "fit" into the design as well as the level of complexity that will "fit" into the design.
    Beau Schwabe
    IC Layout Engineer
    edited 2010-02-08 21:45
    Here is my Propeller II part on a schematic:
    www.leonheller.com/Propeller/Propeller%20II.pdf
    I've used several gates for the part instead of a single square symbol. It took longer to create it, but it will make schematics easier to follow.
    Leon
    Post Edited (Leon) : 2/8/2010 9:52:44 PM GMT
    edited 2010-02-09 07:33
    Cluso99 said...
    Instead of one nice big, fat ground plate, we'll bring out all the separate grounds and you can tie them together at the PCB level.·If we lumped all the grounds together·ON the die (higher-Z), instead of using·lower-Z off-die connections (bottom plate or discrete ground pins), analog performance would be compromised.
    Yes. It's going to be a matter of how much can fit. I'm hoping for 384KB. The cogs are more complicated this time around, though, so they are going to take up some space, too.
    That is easy to do, but it feels like kind of a kludge.
    After a multi-month detour to finalize the I/O pins, I'm back on FPGA stuff now. There are several small things that need some finalizing before the final schematic can be made. Then, Beau will have a giant Lego project to work on. All the building blocks are designed and laid out already. We've just got to put them all together.
    No.
    Chip Gracey
    edited 2010-02-09 07:45
    Bill Henning said...
    A few questions...
    Because of power and ground pin needs, not to mention die real estate, I think 64 I/Os is going to fill things up. S we're heading for 2x32-bit I/O ports with 2x32-bit internal ports.
    I don't see where we can give up 16 pins in a way that spreads around the die.
    I see your point, but it would, on the other hand, force you into self-modifying code for pin parameters, whereas with the current scheme, you just select a port number from bits 6,5 of a variable, while bits 4..0 can provide the bit number. This keeps things simple, though I understand your rationale for wanting discrete port addresses.
    Chip Gracey
  • AleAle Posts: 2,363
    edited 2010-02-09 08:43
    One small question can we use mixed IO voltages ? paraphrased: Are the IO VP/GP pairs all connected together or are they separated ?
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2010-02-09 09:23
    Thanks Chip.
    Cluso said...
    Chip replied...
    and...
    ·Internal ports·is what I meant, so that will be fantastic jumpin.gif·· You can bet we will find lots of uses for these idea.gif
    Ale: my understanding was that each group of 8 pins was to be seperately powered and this would fit the layout.
    edited 2010-02-09 09:58
    Cluso99 said...
    Internal ports is what I meant, so that will be fantastic jumpin.gif You can bet we will find lots of uses for these idea.gif
    Could someone explain about the internal I/O ports (I'm a bit confused)? Would these be spare ports ready to bring out if a bigger IC package is used? or have some other use I've missed?
    - Tony
    edited 2010-02-09 10:18
    TonyD: They are just extra I/O ports which do not have the pad circuitry in the chip. We could use them for communication, indication, etc, between cogs.
    edited 2010-02-09 10:38
    Cluso99: Thanks for the quick reply. Yes it makes sense to me now.
    - Tony
  • AribaAriba Posts: 2,694
    edited 2010-02-09 12:41
    May I suggest to swap the XO/XI with RESn/BOEn pins?
    This would make the layout for the PropPlug connector much easier (Res, P31, P30 near to each other).
    On Prop1 I always have problems to route the reset line around half the Print, because it is in the opposite side from the P31/P30 pins.
    Andy
