FT232RL - Resetting when no USB cable is attached. — Parallax Forums
DavidMDavidM Posts: 640
edited 2010-02-07 15:34 in Propeller 1
HI,
I have a USB Adaptor I have made, using the FT232RL Chip, ( see attached schematic)
My circuit has a built in PROP RESET DISABLE function which works really well, avoiding the reset issues when the unit is operating normally.
However when there is NO USB cable plugged into my USB Adaptor, and I have the RESET DISABLE deactivated ( to allow propeller eprom writing) I have noticed that my 2 leds' RX & TX will FLASH every 10 seconds ( approx) , When I plug a USB cable in ( and the other end is connected to my PC) the LEDS don't flash and no resetting occurs.
Can someone explain what is happening?
It appears that the USB Chip wants to communicate with a USB Host?
Are there any settings in MPROG that can disable this "POLLING"
I have INVERTED the DTR# pin via the MPROG utility.
I have configured the 232RL to self powered.
Dave M
Post Edited (DavidM) : 2/6/2010 8:37:40 AM GMT
