servo code
I got my first standard servo and have been looking over the datasheet and centerservo.spin file to understand how to move it correctly and hold the position. I had no problem converting to pasm but I would like some clarification. Am I correct in that the statement ctra[noparse][[/noparse] 8..0 ] := 0 is not required since the previous statement setting nco mode sets all other bits to zero? The servo is on p0. Also, why is frqa set to 1? Is it simply a non-zero value and could be any value?
'CenterServo.spin
CON
_clkmode = xtal1 + pll16x ' System clock → 80 MHz
_xinfreq = 5_000_000
PUB TestPwm | tc, tHa, t
ctra[noparse][[/noparse] 30..26 ] := %00100 ' Configure Counter A to NCO
frqa := 1
dira[noparse][[/noparse] 0 ]~~
' Set up cycle and high times
tC := (clkfreq/1_000_000) * 21_500
tHa := (clkfreq/1_000_000) * 1500
t := cnt ' Mark counter time
repeat ' Repeat PWM signal
phsa := -tHa ' Set up the pulse
t += tC ' Calculate next cycle repeat
waitcnt(t) ' Wait for next cycle
CON
_clkfreq = 80_000_000
PUB main
cognew(@servo_test,0)
DAT
org
servo_test or ctra,_nco
mov frqa,#1
or dira,counter ' servo pin p0
mov time,cnt
:loop mov this_pulse,servo_center ' center servo
call #pulse_out
mov this_pulse,servo_left ' left
call #pulse_out
mov this_pulse,servo_right ' right
call #pulse_out
jmp #:loop
pulse_out mov counter,#32
[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]_loop neg this_pulse,this_pulse
mov phsa,this_pulse
add time,delay
waitcnt time,delay
djnz counter,#[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]_loop
pulse_out_ret ret
_nco long %00100 << 26
counter long 1 ' used as servo pin, then counter
servo_left long 80_000 ' 1.0 ms
servo_center long 120_000 ' 1.5 ms
servo_right long 160_000 ' 2.0 ms
delay long 1_600_000 ' 20 ms
this_pulse res 1
time res 1
The idea behind the driver is that the PHSA register is set to a negative number. So when you start adding 1 to the PHSA register starts counting down.
And all negative numbers have the MSB bit set which is the servo output. Have your cog reseting the counter in a loop and you get your servo pulse width output.
Nyamekye,
