servo code
I got my first standard servo and have been looking over the datasheet and centerservo.spin file to understand how to move it correctly and hold the position. I had no problem converting to pasm but I would like some clarification. Am I correct in that the statement ctra[noparse][[/noparse] 8..0 ] := 0 is not required since the previous statement setting nco mode sets all other bits to zero? The servo is on p0. Also, why is frqa set to 1? Is it simply a non-zero value and could be any value?
'CenterServo.spin CON _clkmode = xtal1 + pll16x ' System clock → 80 MHz _xinfreq = 5_000_000 PUB TestPwm | tc, tHa, t ctra[noparse][[/noparse] 30..26 ] := %00100 ' Configure Counter A to NCO ctra[noparse][[/noparse] 8..0 ] := 0 frqa := 1 dira[noparse][[/noparse] 0 ]~~ ' Set up cycle and high times tC := (clkfreq/1_000_000) * 21_500 tHa := (clkfreq/1_000_000) * 1500 t := cnt ' Mark counter time repeat ' Repeat PWM signal phsa := -tHa ' Set up the pulse t += tC ' Calculate next cycle repeat waitcnt(t) ' Wait for next cycle
CON _clkmode = xtal1 + pll16x _clkfreq = 80_000_000 PUB main cognew(@servo_test,0) DAT org servo_test or ctra,_nco mov frqa,#1 or dira,counter ' servo pin p0 mov time,cnt :loop mov this_pulse,servo_center ' center servo call #pulse_out mov this_pulse,servo_left ' left call #pulse_out mov this_pulse,servo_right ' right call #pulse_out jmp #:loop pulse_out mov counter,#32 [img]http://forums.parallax.com/images/smilies/tongue.gif[/img]_loop neg this_pulse,this_pulse mov phsa,this_pulse add time,delay waitcnt time,delay djnz counter,#[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]_loop pulse_out_ret ret _nco long %00100 << 26 counter long 1 ' used as servo pin, then counter servo_left long 80_000 ' 1.0 ms servo_center long 120_000 ' 1.5 ms servo_right long 160_000 ' 2.0 ms delay long 1_600_000 ' 20 ms this_pulse res 1 time res 1
The idea behind the driver is that the PHSA register is set to a negative number. So when you start adding 1 to the PHSA register starts counting down.
And all negative numbers have the MSB bit set which is the servo output. Have your cog reseting the counter in a loop and you get your servo pulse width output.
Nyamekye,
