Understanding FSRW flush
I'm working on a simple data logger using two MCP3208s. My ADC seem to occur ever 1.5 ms or so. Which is plenty fast. But, it seems to take about 0.4 seconds to do pwrite and pflush, independent of how much data I'm writing. Is this normal?
CON
_clkmode = xtal1 + pll16x ' Crystal and PLL settings.
_xinfreq = 5_000_000 ' 5 MHz crystal.
cpin1 = 20
dpin1 = 21
spin1 = 22
cpin2 = 27
dpin2 = 24
spin2 = 26
OBJ
sd : "fsrw"
mcp1 : "MCP3208" ' ADC Object
mcp2 : "MCP3208"
DAT
FileName byte "data.bin",0
VAR
long Buff[noparse][[/noparse]5000]
PUB go | counter, i, j, k
sd.mount(0)
sd.popen(@FileName, "a" )
mcp1.start(dpin1,cpin1,spin1,%11111111)
mcp2.start(dpin2,cpin2,spin2,%11111111)
repeat
repeat j from 0 to 99
k := j*13
buff[noparse][[/noparse]0+k] := cnt
repeat i from 0 to 7
buff[noparse][[/noparse]i+1+k] := mcp1.in(i)
repeat i from 0 to 3
buff[noparse][[/noparse]i+8+1+k] := mcp2.in(i)
sd.pwrite(@buff,4*13*100)
sd.pflush
sd.pclose
sd.unmount
fast, but the SD card can have a significant delay at various times.
I would not be shocked to see a 0.4s delay for a flush every, say, 100 to 1000 writes, but most of the time
it should be *significantly* faster than this.
Note that the flush updates the data block, possibly a FAT block, and the directory block, so there's a fair
amount of writing going on, and the wear leveling code may need to scramble to find the appropriate
erase blocks to work with.
I would drop the flush unless you *really* need it and let pclose() finish things off. If it's a perpetual loop,
then you need to trade off buffering required vs how much data you lose to evaluate how frequently you want
to flush.
What kind of card are you using, and how do you have it formatted?
The 0.4 seconds is very repeatable with the above code - every write/flush takes about 0.4s per the cnt output to the file. I can upload an example ifyou're interested.
I guess i'm greedy because I want all my data at a fixed sample rate [noparse]:)[/noparse] So re-wrote this a little with two alternating buffers and a dedicated cog for acquiring the samples.
It works if the repeat until loops are commented out, but of course there is no timing between the writing and the reading to the buffer. If i uncomment the repeat until loops, nothing is ever written to the file.
CON _clkmode = xtal1 + pll16x ' Crystal and PLL settings. _xinfreq = 5_000_000 ' 5 MHz crystal. OBJ sd : "fsrw" log: "buffLog" DAT FileName byte "data.bin",0 Buff1 long 1 [noparse][[/noparse]2500] Buff2 long 2 [noparse][[/noparse]2500] flag1 byte True flag2 byte True PUB go | counter, i, j, k sd.mount(0) sd.popen(@FileName, "a" ) log.start(@Buff1,@Buff2,@flag1,@flag2) repeat ' repeat until (flag1 == True) ' Next sd.pwrite(@buff1,4*13*150) sd.pflush ' repeat until (flag2 == True) ' Next sd.pwrite(@buff2,4*13*150) sd.pflushOBJ mcp1 : "MCP3208" ' ADC Object mcp2 : "MCP3208" CON cpin1 = 20 dpin1 = 21 spin1 = 22 cpin2 = 27 dpin2 = 24 spin2 = 26 VAR long Stack[noparse][[/noparse]120] 'Stack space for new cog byte Cog 'Hold ID of cog in use, if any PUB Start(bufAdd1,bufAdd2,fAdd1,fAdd2): Success {{Start new servo input process. Return True if successful.}} Stop Success := (Cog := cognew(log(bufAdd1,bufAdd2,fAdd1,fAdd2), @Stack) + 1) PUB Stop {{Stop toggling process, if any.}} if Cog cogstop(Cog~ - 1) PUB Active: YesNo {{Return TRUE if process is active, FALSE otherwise.}} YesNo := Cog > 0 PUB log (buffAdd1,buffAdd2,flAdd1,flAdd2) | i,j,k mcp1.start(dpin1,cpin1,spin1,%11111111) mcp2.start(dpin2,cpin2,spin2,%11111111) repeat Byte[noparse][[/noparse]flAdd1] := False repeat j from 0 to 149 k := j*13 LONG[noparse][[/noparse]buffAdd1][noparse][[/noparse]0+k] := cnt repeat i from 0 to 7 LONG[noparse][[/noparse]buffAdd1][noparse][[/noparse]i+1+k] := mcp1.in(i) repeat i from 0 to 3 LONG[noparse][[/noparse]buffAdd1][noparse][[/noparse]i+8+1+k] := mcp2.in(i) waitcnt(cnt + 218_560) Byte[noparse][[/noparse]flAdd1] := True Byte[noparse][[/noparse]flAdd2]:= False repeat j from 0 to 149 k := j*13 LONG[noparse][[/noparse]buffAdd2][noparse][[/noparse]0+k] := cnt repeat i from 0 to 7 LONG[noparse][[/noparse]buffAdd2][noparse][[/noparse]i+1+k] := mcp1.in(i) repeat i from 0 to 3 LONG[noparse][[/noparse]buffAdd2][noparse][[/noparse]i+8+1+k] := mcp2.in(i) waitcnt(cnt + 218_560) Byte[noparse][[/noparse]flAdd2] := TrueMCP3208 hardware) that writes a file that includes the cnt samples (in ASCII would be nice)
and include the file it generates in the zip. I'll run it on my hardware here and my cards and
compare.
