The Spin Zone - Update #5
http://www.parallax.com/Resources/NutsVoltsColumns/TheSpinZone/tabid/781/Default.aspx
A new article has been posted for "The Spin Zone" - March 2010, BASIC Propeller Programming.
Follow the link above to "The Spin Zone" articles or...
Column - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Code - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/code/nvp5.zip
PropBASIC gets it's day in the sun.
Thanks, Jon.
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
Post Edited (Bean) : 2/2/2010 12:16:22 PM GMT
"The IDE actually times the Propeller as part of the download protocol and
then adjusts the baud rate from the IDE to accommodate the individual chip."
</quote>
Err.. no it doesn't. The Propeller times the first incoming byte (actually a bit in that) and adjusts its world view of what it thinks the "BAUD" rate is..
Life may be "too short", but it's the longest thing we ever do.
Jon McPhalen
Hollywood, CA
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
More that likely I will not receive my hard copy as Nuts & Volts has gone missing 4 times in the last 2 years. Once again I have not received this months issue so I appreciate the Parallax link.
