The Spin Zone - Update #5 — Parallax Forums
BumpBump Posts: 592
edited 2010-02-02 15:48 in Propeller 1
http://www.parallax.com/Resources/NutsVoltsColumns/TheSpinZone/tabid/781/Default.aspx
A new article has been posted for "The Spin Zone" - March 2010, BASIC Propeller Programming.
Follow the link above to "The Spin Zone" articles or...
Column - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Code - http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/code/nvp5.zip
  • BeanBean Posts: 8,129
    edited 2010-02-01 21:55
    OH YEAH !!!!
    PropBASIC gets it's day in the sun.
    Thanks, Jon.
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    Post Edited (Bean) : 2/2/2010 12:16:22 PM GMT
  • BradCBradC Posts: 2,601
    edited 2010-02-01 23:43
    <quote>
    "The IDE actually times the Propeller as part of the download protocol and
    then adjusts the baud rate from the IDE to accommodate the individual chip."
    </quote>
    Err.. no it doesn't. The Propeller times the first incoming byte (actually a bit in that) and adjusts its world view of what it thinks the "BAUD" rate is..
    Life may be "too short", but it's the longest thing we ever do.
  • JonnyMacJonnyMac Posts: 9,800
    edited 2010-02-02 01:32
    Whoops... my bad -- I was sure that's how it was explained to me; should have double-checked. Will correct in the next issue.
    Jon McPhalen
    Hollywood, CA
    edited 2010-02-02 01:50
    Nice article, as always [noparse]:)[/noparse]
    JonnyMac said...
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
  • WurlitzerWurlitzer Posts: 237
    I concur very nice article!
    More that likely I will not receive my hard copy as Nuts & Volts has gone missing 4 times in the last 2 years. Once again I have not received this months issue so I appreciate the Parallax link.
