Computer quere
My CRT monitor suddenly decided to go pink. I understand this is not unusual for older monitors. A friend had a monitor he wasn't using and ended up just giving me the whole system. The monitor works great on my computer. But I found the computer worked just fine by hooking it to my old pink monitor. I had hoped to use this system in the shop but found it had only 35 meg of RAM and the system maxed out at 256 meg.Ram cards are about 6-10 dollars, but even maxed out would it run the stamp editor? I have plenty of hard drive space but the program won't install with only 32 meg.
EverQurious
Try not to fret and worry bout the things that you have not...
Just remember to be thankful for the things you've got !!!
EverQurious
You could run a version of Linux on that amount of ram.
basic stamp on linux
If you convince yourself that something is impossible before you even try; you are sure to prove yourself right.
Post Edited (silverback) : 2/1/2010 11:52:30 AM GMT
