Servo pulse requirements
So all servos have a center pulse of 1.5 ms sent every 20 ms. But if you sent a 2 ms pulse, does the time in between shorten to 19.5 ms or does it stay 20 ms.
·········· ___········ ___········ ___
·· _____|·· |_____|·· |_____|·· |_____
····· 20··1.5··· 20···1.5·· 20·· 1.5···· 20
···········____······ ____·······____
·· _____|··· |____|··· |____|··· |_____
···· 19.5·· 2·· 19.5·· 2··19.5·· 2··· 19.5
"You do not really understand something unless you can explain it to your grandmother."
-Lucky[size=-1][/size]
As far as what actually happens, that depends on what you've programmed.
Some servos have a center pulse of 1.520 mS.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
