Accessory Backpack for PSB: Wifly+Ramblade+IR+Battery+RTC+I/O...
I've been working on this all day and it's starting to take shape!
I'm pretty excited about this, so wanted to share...
This board with (hopefully) connect to the back of the PSB.
It's going to be all through-hole...·
Going to try a trick with the Wifly and solder the pads through holes in the board...
Spot for a Ramblade, and if not, then a proto area.
3 AA cell holder in the middle and 5V booster in top right.
I2C RTD DS1307 in top middle (with coin cell backup)·and I2C I/O expander next to it
Parallax IR transmitter and receiver mounts on top.
Little speaker and microphone mounts on bottom center.
Plenty of proto areas...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
http://designedbymemicros.blogspot.com/
Check out the Propeller Wiki·and contribute if you can.
JMH
This may be the final cut:
Cluso:· Thanks for providing the Ramblade for a very nice price!· If my understanding is right, I just need to come up with a VT100-like terminal program for the PSB and then can run huge XMM programs on the Ramblade and just use the PSB as text terminal...
Maybe I can do a terminal app with an on-screen keyboard...
Do you have an eta (really rough approximate is fine) for when one of these will be done and available to buy?
