Enclosure for Propeller Demo Board — Parallax Forums
edited 2010-02-28 02:39 in Propeller 1
The Propeller Demo Board is full-featured enough that it could find ahome in many end applications — if it only had a decent enclosure. The board doesn't have any mounting holes, and neither the on-off switch, the power LED, nor the A16-A23 LEDs are board-edge accessible. If a board isn't designed around a particular enclosure, finding one after the fact can be a challenge.
I had a scrap piece of extrusion lying around (Lansing Micro-Pak DQ0), which was too wide for the board (better than too narrow!) and long enough that I could cut it to the Demo Board's 3.01" (including the VGA connector's slight overhang) length. Then I designed some laser-cut acrylic parts to hold the board in place inside the extrusion, along with laserable laminate end panels having cutouts for the connectors.
I was tempted to add a separate on/off switch, but I didn't want to make any modifications at all to the Demo Board. It occurred to me that a piece of acrylic could be crafted to grab the switch slider and protrude from the rear panel in a pull on/push off fashion. It also occurred to me that the same piece of acrylic could be used to direct the light from the LED to the end of the panel protrusion when the board is turned on. The "lightpipe" view below shows the switch/LED gizmo, the "innards" view shows it in place, and the "rear" view shows it in action.
I was going to call it quits at this point, but those eight amber LEDs gnawed at me. I figured that if the acrylic worked as a light pipe over a short distance, it might work just as well over a longer one. So I designed the bigger one shown in the "lightpipe" photo and shown installed in the "innards" photo. I had to connect the eight individual pipes together at intervals just to keep them unitized so they wouldn't flop around like spaghetti. This results in a little bit of optical crosstalk between adjacent pipes. As a consequence, the resulting panel display's utility as eight individual status lights might be limited. But it's great for things like graphical level meters.
Anyway, I don't know what I want to do with this now that I have it. But it was fun solving the problems encountered along the way. I suppose, if there were adequate demand, I could make more of them.
_
    edited 2010-01-29 23:33
    That looks FANTASTIC Phil.
    I wish I had your mechanical skills and workshop.
    Phil Pilgrim (PhiPi) said...
    _
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
  • John R.John R. Posts: 1,376
    edited 2010-01-29 23:42
    Nice work with the new laser.
    What I've seen done for "multi-conductor" light pipes, is a separate piece of black plastic used as "stringers" to tie the various pieces together. This eliminates/minimizes the cross talk.
    John R.
    Click here to see my Nomad Build Log
    edited 2010-01-30 01:10
    The lightpipes are actually quite a simple concept although trial and error is often needed. Sometimes it is better to use a straight lightpipe and add a 90 degree bend with a 45 degree angle to cause the light to be reflected. I used lightpipes in my modems in the 90's. It took a bit of filing to·find the best method. I used seperate fingers to pick up the leds and the fingers were only joined at the outer surface. This ensured no bleed between the leds. BTW, I used superbright smt LEDs (of the day) and 3K3 resistors to 5V giving 1mA per LED.
    I will look for my lightpipes and post a photo here later.
  • eod_punkeod_punk Posts: 146
    edited 2010-01-30 01:53
    Really nice work Phil, what did you use to make the labeling?
    There is no problem that can't be solved with a suitable amount of explosives!
    EOD Memorial
    edited 2010-01-30 02:17
    Thanks, guys! The labeling was engraved on the laser cutter from a two-color acrylic laminate, 1/16" thick. The top, black layer is only 3 mils thick and burns off easily, revealing the silvery base layer. Engraving is done raster-style, back and forth. Imagine a one-nozzle inkjet printer, but with a concentrated infrared laser beam instead of ink, and you'll get the idea. The outline and holes are done after rastering, vector-style and at a slower speed so it burns all the way through.
  • BeanBean Posts: 8,129
    edited 2010-01-30 02:32
    Phil,
    Very nice job.
    What would be the cost for one or more ?
    Bean
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134·
  • TubularTubular Posts: 4,727
    edited 2010-01-30 02:39
    Great stuff, Phil. I especially like the girder work on the inside. Are you using 3D cad or doing your head in using 2D?
    Looks like you've also managed to label the clear parts "RF" etc on a lower power setting.
    cheers
    tubular
    edited 2010-01-30 03:09
    Cluso99 said...
    The main reason I used a radius instead was that I had to fish the turn through a slot in the support structure. With R/A mirroring, I would have had to increase the slot length by a factor of 1.414, and it would've been too sloppy to keep the light pipe from moving.
    Bean said...
    Probably kinda steep. Lansing's price on their standard extrusion lengths runs about $17-$20. So I'd have to buy probably 50 custom cut ones to get that price. The acrylic isn't all that expensive, but there's time on the machine to cut and engrave it. I'll see how much interest I get and go from there.
    Tubular said...
    2D with Corel Draw. And a lot of time spent with calipers, measuring the PCB and its part locations. Oh, and a lot of trial and error after the fact.
    Tubular said...
    Yes: RF = Right Front; LF = Left Front. It makes assembly simpler — even for the guy who designed it! smile.gif
    Post Edited (Phil Pilgrim (PhiPi)) : 1/30/2010 3:20:30 AM GMT
  • wjsteelewjsteele Posts: 697
    edited 2010-01-30 03:27
    Bill
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-01-30 17:30
    That's very cool! What is the vertical clearence on the breadboard to the inside top of the case?
    I want a few if you go into production BTW.
    Signature space for rent!
    Send $1 to CannibalRobotics.com.
    edited 2010-01-30 18:02
    Hi PhiPi,
    does this mean you got a laser-scanner with enough power to cut plastic?
    I worked in a company that manufactured laser-scanners to mark and cut special foils. They use High-power-laserdiodes to pump a YAG-laser which resulted in
    an optical power of 30W. This was not really enough to cut bigger plastics than the foils with 0.5mm. So how much power does your laser have?
    best regards
    Stefan
    edited 2010-01-30 18:04
    These go on sale when????
    Awesome case! How about moving the breadboard to the top?
    OBC
    New to the Propeller?
  • Paul Sr.Paul Sr. Posts: 435
    edited 2010-01-30 18:43
    I would think if you need the breadboard EXPOSED, then you probably don't need an ENCLOSURE, right???
    edited 2010-01-30 19:35
    CannibalRobotics said...
    Slightly over 0.35 inches.
    StefanL38 said...
    Yes, 35W CO2 laser (Epilog Zing). It will cut through up to 1/4" acrylic in one pass.
    OBC said...
    The idea is to house and protect a finished product, once any breadboarding is complete. There's room on the left side of the front panel for a connector that can interface to some internal breadboarded circuitry, if necssary.
    Post Edited (Phil Pilgrim (PhiPi)) : 1/30/2010 7:40:21 PM GMT
  • CassLanCassLan Posts: 586
    edited 2010-01-30 19:57
    That is very impressive Phil.
    Makes me want to finish up my DIY CNC mill!
    Rick
    PrEditor·- Text Editor
    NYC Area Prop Club
  • hinvhinv Posts: 1,255
    edited 2010-01-30 20:11
    Wow Phil, I am really impressed, especially with the light pipes. Anybody but me notice that those LEDs are a bit too bright? Are they acceptably dimmed after going through the light pipes?
    Doug
    edited 2010-01-30 20:58
    It's so much neater than my version in an old tape case. As soon as you try to get the Breadboard to the outside world it all gets a bit messy.
    Style and grace : Nil point
    edited 2010-01-31 04:43
    Very cool piece of work.
    I love it when you gurus show what you can do. This light pipe thing is especially awesome.
    thanks for sharing!
  • WBA ConsultingWBA Consulting Posts: 2,937
    edited 2010-02-02 00:51
    Good work Phil! Your end panels came out really nice and I think they are more than the icing on the cake. Does a standard USB connector reach the socket or do you have to use one of the longer styles? I agree for the reasons you mention that the DemoBoard is terrible when it comes to an enclosure design.
    I have my demoboard in a Polycase plastic enclosure and had to enlarge the USB opening to make room for the connector molding to fit through so it actually looks like I messed it up. The holes on mine are overlapping the base and lid, so that's another downfall. The board is only secured in by friction. My setup does work good enough for me though (aka: it already survived a drop tongue.gif ) with an ~hour of step-drilling and nibbling. More details on the case are on this thread. I would consider it a one time thing, not something that's suitable for production quantities.
    One of my Propeller Contest Entries is a full Propeller Development PCB that fits into a case that works well as a handheld or desktop enclosure. I may have to have you do the end panel!
    Andrew Williams
    WBA Consulting
    Special Olympics Polar Bear Plunge, Mar 20, 2010
    Propeller-Based Reverse Geo-Cache Birthday Present Project
    Post Edited (WBA Consulting) : 2/2/2010 1:03:46 AM GMT
    1024 x 717 - 82K
    429 x 336 - 16K
    421 x 336 - 16K
    430 x 336 - 12K
    edited 2010-02-02 01:06
    Bravo! Beautiful and inspired work.
    edited 2010-02-02 02:54
    WBA,
    The USB connector on my Demo board extends over the edge just a hair, and the panel is only 1/16" thick. The molding on a standard USB connector fits snug against the panel, but it's inserted all the way. IOW it just makes it.
    It's interesting to note that the mouse and keyboard connectors are designed to hang over the edge; but they don't, since they're too far back on the board. As a consequence, they tilt upwards a little, and the bottom of the connector housing is pinched inwards a bit from the extra pressure. These connectors would work better with an overhang and a rectangular panel opening, but they're also fine the way they are.
  • yarisboyyarisboy Posts: 245
    So often we get it working and then look for a suitable enclosure. I couldn't make the deadline for the Prop contest so now I have the time to make the boards "perfect" for the enclosure
    MOORE'S LAW: The capabilities of electronics shall double every 18 months.
    cloyd's corollary: Hardware is easy, software is hard.
    2048 x 1536 - 870K
