Robot Vision/Camera
Hey, I have been interested for a while in robotic vision and I had been wondering how one would implement vision onto a robot.· I have already seen a tutorial on methods to use·in applications such as blob tracking, but I don't know how to actually get a camera onto a robot.· Could I hack into a USB Camera? (USB has 4 pins for GND, 5V Power, and Data In and Out).· And, could one use the robots microcontroller to process images, or do you need to have a connection to an external computer?· And one more thing.· Does anyone know of some good robot vision processing software?
SB 3:16
SB 3:16
No. It's possible to do some processing, like blob tracking, using a fast microcontroller with enough memory attached, but you'd be using a low resolution image subset for this (like 128 x 64 pixels) because of speed and memory constraints.
No. You'd need to use a USB-host capable microcontroller and, because of throughput limitations, you'd at best be able to work with a subset of the image. If you really mean "hack into", like bypassing the USB interface, you might be able to, but would probably need a lot of hardware and speed / throughput would still be an issue.
Do you need to have a connection to an external computer?
Probably.
Have you looked at the CMUcam website? www.cs.cmu.edu/~cmucam/
Have you looked at the ViewPort website? hannoware.com/viewport/features.php
SB 3:16
I, too, run off an iMac, and use VMware Fusion to drop into Windows XP mode to run most of the development software, including Roborealm
a very nice image processing suite: http://www.roborealm.com/
Once I get things up and running, I'm planning to upgrade to the Surveyor's SVS (Stereo Vision System): http://www.surveyor.com/stereo/stereo_info.html
And are there any (other) programs that are free that do things like roborealm or viewport?
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
That's what I say anyway.
SB 3:16
Jim
i think OpenCV its for you:
it's openSource, you can take it with windowXP or better, or with Linux.
it's good community in computer vision, it's gives some good source-code, a book "learning opencv" from o'relly.
·i take this on my bot with a usbWebcam on a laptop (sitting on the bot) under linux, a propellerRobotControllerBoard for
the Motors, a interface to propellerProfessionalDevelopmentBoard with 7 x Ping and 1 x HM55B-compass module and serialInterface (usb-to-rs232) to the laptop
with a second webcam you can control your bot with your head or your hand :-) (PS2mouse, touchscreen, or your control the stuff with a wiimote :-)
regards nomad
·The Paypal link still works, so it's probably good. An easy download. They give you free updates for a year.
I installed it and it works on my PC, but I·have not really had a chance to play with it yet.
I started out with the prop not long time ago and got hooked really good!
Now, I want to find a solution how to position a tool. Think of it as placing the gastap into your car - thats about the precision needed. Also, I will be able to rely some on stored coordinates, so its the last finishing I need to "see"
I like to do that! I want to experiment with vision and don't need it to be particulary fast or hi precision. Should I aim to get the data into a cogram as a matrix(small, just black/white zeros/ones one pixel repr. by a bit probably 64x32 or so) OR is it the hubram I must use?
Yes - and Viewport, though an excellent thing, does require a PC (no?)
CMUcam - it would probably solve the need, but I like to learn som along the way.
I like to know if I can use something like the module on the CMUcam, but scale it to be feasible on the propeller!
Anything to help me going is VERY appreciated. many thanks in advance!
Most people use ViewPort on a PC for debugging, real-time graphing of variables/pin states and to control devices with OpenCV. However, it also comes with 2 objects you can run on your Propeller that don't require a PC connection:
PropCapture will capture NTSC video at full frame rate at configurable resolutions into memory (max is 240x200 at 16 grayscales). Normally you would stream this to ViewPort for analysis with OpenCV or just to look at yourself. However, you can also use:
PropCVFilter applies simple computer vision filters to video frames in HUB. Things like Soebel filters, min/max...
You can combine both (like I did in my DanceBot) to create an autonomous robot that uses vision to interact with people or other things in its environment- very fun!
Read more:
in my circuit cellar article:http://www.circuitcellar.com/archives/viewable/224-Sander/index.html
in the official propeller book: http://www.amazon.com/Programming-Customizing-Multicore-Propeller-Microcontroller/dp/0071664505
Hanno
Hi Hanno!
Well - what do you know! It turned out to be a good idea to ask
I have just quickly gone through the suggested links - and found them very promising. I'll take some time to go through deeper and I probably get even more curious and eager to get on with my own experimenting.
Thanks a lot for the tips!
