Reset pin on BS2p24
A real quick question:
The manual did not mention a resistor, while a search in these forums give me nothing.
Should the Reset pin be pulled low through a resistor, or is a button straight to ground acceptable?
A 100k did not reset, I tried several other values leading up to the 1k I have in there now. Is this resistor required? I've not noticed an ill-effect jumping it straight to ground, but I don't want to damage anything.
Thank you.
Dave
Dave Andreae
Parallax Tech Support·
I thought I'd read the entire manual for this little guy, and I did not know about the pull up resistor.
I should have known regardless. otherwise the reset pin is hanging off susceptible to noise. Guess I didn't consider it before.
Thanks fellas, for answering the question and for the extra info there.
