Accessory Backpack for PSB: Wifly+Ramblade+IR+Battery+RTC+I/O... — Parallax Forums
RaymanRayman Posts: 16,061
edited 2010-01-30 21:59 in Propeller 1
I've been working on this all day and it's starting to take shape!
I'm pretty excited about this, so wanted to share...
This board with (hopefully) connect to the back of the PSB.
It's going to be all through-hole...·
Going to try a trick with the Wifly and solder the pads through holes in the board...
Spot for a Ramblade, and if not, then a proto area.
3 AA cell holder in the middle and 5V booster in top right.
I2C RTD DS1307 in top middle (with coin cell backup)·and I2C I/O expander next to it
Parallax IR transmitter and receiver mounts on top.
Little speaker and microphone mounts on bottom center.
Plenty of proto areas...
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
