Name that board.
I am still waiting for Brian to give me the OK on this board but it needs a name. I will give one board free to the person that comes up with the best name(as voted by the forum members). Name and vote deadline is Tuesday February 2nd at 11:59PM CST. Boards should be available for order by the end of February.
What is this board? It lets you use your Spin Studio, Propeller Platform, MoBo, LCD Breakout, and ProtoBoard Modules on both the SpinStudio and Propeller Platform.
Names so far
Accumulator - kuroneko
AllPropBase - Duffer
Anna Dapter - Toby Seckshund
Babelprop - wjsteele
Babelfish - localroger
Borgzilla - Bill Henning
Configurator - Timothy D. Swieter
CrossDresserBoard* - MagIO2
Duct Tape* - Nick McClick
Enginuity - SRLM
Famous Potatoes - sylvie369
FreeProp - microcontrolled
Holdall - kuroneko
Insestigator - Graham Stabler
IPad* - sylvie369
ironing - BradC
Outboard - OakGraphics
Lobbyboard - Oldbitcollector
MaxiPad* - ElectricAye
McBoard - Rsadeika
Not-a-shield - Oldbitcollector
Plug 'n' Prop - microcontrolled
Prop-a-Doodle-Do - ElectricAye
Propazog, from dimension 13-B - lonesock
PropBase - Duffer
PropBridge - OakGraphics
Propeller Extender Board - Cheyenne
Propellerized - microcontrolled
Propeller Universal Adapter Board - microcontrolled
PROPer Connections - microcontrolled
PropFormer - MagIO2
PropMAX - microcontrolled
Promulgrating Propricious Propulus Propulator - CannibalRobotics
Prop Multi Access - hover1
Prop Multilangual Board - hover1
Proptalk - MajorStrain
Proptavion - microcontrolled
Proptimus - Dragon
Proptopus - wjsteele
Propular connectors - Oldbitcollector
PropX - microcontrolled
PropXtender - Cheyenne
PropZetta - Shmoopy
Pusher Prop - lonesock
ReSpun - microcontrolled
RosettaProp - Shmoopy
Spinboard - microcontrolled
SPINit - microcontrolled
SpinOut - Roy Carlson
SpringBoard - Clint
Surfboard - Oldbitcollector
tailspin - icepuck
TheBorg - Bill Henning
thing-a-ma-jig - Oldbitcollector
Transmogrifier - BradC
UHURU(Swahili for freedom) - WBA Consulting
UnSpun - microcontrolled
VersaBoard - blittled
Wizard - humanoido
XProp - microcontrolled
Xtalk board - MajorStrain
*Can't use
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
Post Edited (mctrivia) : 1/30/2010 1:48:20 AM GMT
Names so far
Enginuity - SRLM
Holdall - kuroneko
IPad* - sylvie369
ironing - BradC
McBoard - Rsadeika
PropBase - Duffer
PropFormer - MagIO2
Proptimus - Dragon
PropZetta - Shmoopy
SpringBoard - Clint
tailspin - icepuck
Wizard - humanoido
*Can't use
Style and grace : Nil point
Bill
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
humanoido
humanoido
*Stamp SEED Supercomputer *Basic Stamp Supercomputer *TriCore Stamp Supercomputer
*Minuscule Stamp Supercomputer *Three Dimensional Computer *Penguin with 12 Brains
*Penguin Tech *StampOne News! *Penguin Robot Society
*Handbook of BASIC Stamp Supercomputing
*Ultimate List Propeller Languages
*MC Prop Computer
Of course... but a slight modification is needed to make it more prop like. How about Babelprop?
So long and thanks for all the fish!
Bill
Life may be "too short", but it's the longest thing we ever do.
Could also be called Proptalk with the same logo.
Cheers
Phil
There must be a collective awareness... babelfish and babelprop was the first idea I had, but I rejected it because that was more·about translating and not transforming ;o)
Post Edited (MagIO2) : 1/29/2010 1:55:24 PM GMT
Transmogrifier
Martin Hodge
webbolts.com
forumexperts.com
Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
Will work for Propeller parts!
http://www.nytimes.com/2010/01/29/technology/29name.html
-or-
Borgzilla
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Powered by enthusiasm
Just a heads up regarding the MoBo connector: the pin pitch is 2mm.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
Post Edited (Clint) : 1/29/2010 6:42:25 PM GMT
