More Issues...
Well, I have the hydra plugged in right now, along with the 512K SRAM expantion card. The 3.3v power limiter is painfully hot to the touch, and my computer says "No propeller chip found" when I try to download a program. My power lights are all on, (Including the one on the SRAM card). Debug lights 1 and 2(on the sram) are lit. i think I am running the preloaded SRAM test thingie, and I am getting a very low-frequency signal on my TV port.WHAT IS WRONG HERE?????
If you see a signal, HYDRA is fine, and you've got to go and start doing and learning stuff!
If not, then try inserting the pre-programmed eeprom card. It's got a game programmed on it. These can be inserted wrong, so look the docs over carefully.
Are you sure the power supply is DC? And are you sure it's center positive? Double check those, and do not run the HYDRA for more than 10 seconds or so, until you've sorted things out, just to keep things safe!
8x8 color 80 Column NTSC Text Object
I'm smart, cause' I say smart stuff like this:
"Hardware is what you have if you want to make that little light on the front turn on."
--QUARKSPIN
And...
"Sometimes some stuff does stuff like... um..."
--QUARKSPIN
--QUARKSPIN
And...
--QUARKSPIN
You said that the regulator was hot to touch and now it's at 2v?
Is there a chance that something is shorting somewhere? Bottom of the Hydra, or something plugged in?
I'm really waiting to hear success on this.
OBC
New to the Propeller?
--QUARKSPIN
And...
--QUARKSPIN
I feel so smart, I have it fixed now!
It was just a cooked 3.3V power regulator.
Now, all I have to do is find my SRAM card, and I can make HALO 4!
--QUARKSPIN
And...
--QUARKSPIN
Not a lot has been written for it, IMHO. Good news is those two did write some good, core code.
