More Issues... — Parallax Forums
More Issues...
QUARKSPINQUARKSPIN Posts: 36
edited 2010-02-01 07:05 in Propeller 1
freaked.gif Well, I have the hydra plugged in right now, along with the 512K SRAM expantion card. The 3.3v power limiter is painfully hot to the touch, and my computer says "No propeller chip found" when I try to download a program. My power lights are all on, (Including the one on the SRAM card). Debug lights 1 and 2(on the sram) are lit. i think I am running the preloaded SRAM test thingie, and I am getting a very low-frequency signal on my TV port.
WHAT IS WRONG HERE?????
    edited 2010-01-28 04:25
    You should remove the SRAM card, and fire up the HYDRA, with just the power supply, computer USB and video connected.
    If you see a signal, HYDRA is fine, and you've got to go and start doing and learning stuff!
    If not, then try inserting the pre-programmed eeprom card. It's got a game programmed on it. These can be inserted wrong, so look the docs over carefully.
    Are you sure the power supply is DC? And are you sure it's center positive? Double check those, and do not run the HYDRA for more than 10 seconds or so, until you've sorted things out, just to keep things safe!
    8x8 color 80 Column NTSC Text Object
  • QUARKSPINQUARKSPIN Posts: 36
    edited 2010-01-28 04:44
    Oh, well I think i've fount the problem. The power supply says it's 9V 300 miliamps, but my multimeter says it's put'n out 14V. Does that mean something's wrong with my multimeter? (Oh, and btw, it is DC and centere positive.)
    I'm smart, cause' I say smart stuff like this:
    "Hardware is what you have if you want to make that little light on the front turn on."
    --QUARKSPIN
    And...
    "Sometimes some stuff does stuff like... um..."
    --QUARKSPIN
    edited 2010-01-28 05:56
    Get a fresh 9V cell, connect it, and power the HYDRA for a short time that way. You may have more variables in play here than you know.
    edited 2010-01-29 02:25
    Ok, I think I have it solved now. The 14 V readout was caused by a 7 volt 9 volt (dead) battery in my meter, and the real issue was the 3.3 volt converter, that was putting out 2 volts. Good thing I have a spare on hand...
    --QUARKSPIN
    And...
    --QUARKSPIN
    edited 2010-01-29 03:03
    It almost sounds like something is shorted somewhere...
    You said that the regulator was hot to touch and now it's at 2v?
    Is there a chance that something is shorting somewhere? Bottom of the Hydra, or something plugged in?
    I'm really waiting to hear success on this.
    OBC
    New to the Propeller?
    edited 2010-01-29 04:01
    Well, It isn't shorted Now, But it might have gotten shorted somewhere, resulting in a failure. Like I said, I have a spare, And I'll replace it tomorrow. (And I'm about to test the chip)
    --QUARKSPIN
    And...
    --QUARKSPIN
    edited 2010-02-01 03:16
    I feel so smart, I have it fixed now!
    It was just a cooked 3.3V power regulator.
    Now, all I have to do is find my SRAM card, and I can make HALO 4!
    --QUARKSPIN
    And...
    --QUARKSPIN
    edited 2010-02-01 04:19
    Now that I have it working, does anyone have somewhere I could look for demo programs for the SRAM card?
    There is a Spacewar game written for that card. Jasper_M (and I might have that wrong on the underscore) and EP Moyer? (I for sure have parts of that user name wrong) both worked on that card and video driver stuff.
    Not a lot has been written for it, IMHO. Good news is those two did write some good, core code.
