Hydra power supply? — Parallax Forums
Hydra power supply?
QUARKSPINQUARKSPIN Posts: 36
edited 2010-01-28 00:16 in Propeller 1
shocked.gif Oh no! The power supply for my hydra got put in... THE DRAWER
Could anyone find thiers and tell me what the voltage\amp output is? (The brand name would be good to)
I'm smart, cause' I say smart stuff like this:
"Hardware is what you have if you want to make that little light on the front turn on."
--QUARKSPIN
And...
"Sometimes some stuff does stuff like... um..."
--QUARKSPIN
    edited 2010-01-27 23:13
    A power supply 7.5v-9.0v DC, center positive should work fine.
    OBC
    New to the Propeller?
  • QUARKSPINQUARKSPIN Posts: 36
    edited 2010-01-27 23:39
    How many amps? (So far, I have found a 9-V, 2.2 amp one, a 9-V 220 miliamp one, and a 9-V 300 miliamp one)
    I would use the 300ma one. I'm not sure what the peak draw of a HYDRA is, but it's no where near 2.2Amps!
    Half the time, I'm on an ordinary 9V dry cell and get hours on it before program failure. My AC supply adapter is 500ma, and I've never had trouble.
    8x8 color 80 Column NTSC Text Object
