PMB-648 GPS Part# 28500 - Wrong Datasheet?
I just purchased the PMB-648 GPS unit, I checked the wiring diagram that is listed on the product page and I noticed it has a different pin/wiring, its for the PMB-248...
I can't find the documentation on the PMB-648, it just takes me to the PMB-248 page...
Anyways, here is the pinout of the PMB-648
that is how it is listed on the GPS·board.
I am trying to connect this to the Propeller too, I am new to both GPS and the Propeller so any help would be much appreciated.
Jorge
http://WhatsAvailable.org Software and Gadgets for Windows 7.
Post Edited (Jorge P) : 1/20/2010 6:55:07 AM GMT
- White wire - GND
- Green wire - RX
- Black wire ·- TX
- Red wire··· - VIn
- Blue wire···- RXD
- Yellow wire - TXD
Jorge
I had this GPS module working on my desk last week with parts from OBEX. Chris will provide some pointers for you.
How did you buy this GPS? It's not on our web site yet but we have 500 units in stock.
Post Edited (Jorge P) : 1/20/2010 7:12:32 PM GMT
I just checked the PMB-248 and your pin assignments are incorrect. Conecting them that way will damage the module. If you look closer you will see that those pads on the top of the PCB do not connect directly the wires in the same order below them. This is a multi-layer PCB and for whatever reason they are placed in that order on top of the PCB and it varies from the wiring of the connector. You can verify this by connecting a continuity checker to each pad and the other side to the corresponding wire to match them up. But the wiring diagram is correct.
Best Regards,
Chris Savage
Parallax Engineering
Check out the new Savage Circuits TV!
Consider yourself fortunate - you got the latest and highest performance GPS from Parallax. I'm attaching some specs on the PMB-648 for you since the product is not for sale on-line yet. It's a SiRFStarIII chipset with tracking of 20 satellites and quick signal lock-on. We have two versions of it, too, with and without antenna. The one you have includes internal antenna with no connection for external.
The retail price will be $30-40. I've already provided everything to WebDev to put the two new GPS products (and a nice comparison table) on our web site. Just waiting for them to finish now.
Enjoy the PMB-648!
Sincerely,
Will the PMB-648 support "smart mode" as well as "raw mode" like the #28146?
The current 28146 product is being upgraded to use the PMB-648, however, so it will support the Smart Mode in future production runs.
Are you using a BASIC Stamp?
Yes i am, i have the bs2 and the 28146 right now. i like the smart mode function just for it's simplicity in coding. when the upgraded 28146 comes out, will it have the option with/without antenna?
I see why you want Smart Mode - much easier with the BS2.
Ken
It was extremely accurate, putting the cordinates into google maps, it put an arrow right on my car.
Rec.:852 Ver.:852 Fail:0 (Decoded RMC:236 GGA:237 GLL:0 GSV:141 GSA:237) Last decoded NMEA sentence : RMC GPS Data Status : Valid GPS Navigation Mode : Differential GPS Position Fix Quality : DGPS SPS, Fix Valid Positioning Mode Selection : Automatic 2D/3D Actual Positioning mode : 3D ID of Satellites in View : 14 22 26 19 18 11 9 31 27 32 3 6 Elevation : 88 61 59 25 25 17 17 13 12 11 9 9 Azimuth : 216 82 52 255 94 312 39 175 35 282 230 221 Signal Strength : 26 39 39 30 32 20 31 23 25 16 27 -- ID of Satellites Used in Fix : 19 9 31 3 18 14 26 22 27 11 PDOP, HDOP, VDOP : 1.4 0.8 1.1 Day Month Year(AD) as LONGs : 26 1 2010 UTC Hour Min. Sec. as LONGs : 23 53 11 Latitude in degres as FLOAT : 45.78087 Longitude in degres as FLOAT : -111.1853 Speed Over Gnd [noparse][[/noparse]knots] FLOAT : 0 Course Over Gnd [noparse][[/noparse]degs] FLOAT : 257.09 Magn. Variation [noparse][[/noparse]degs] FLOAT : --.- Alt. at Mean Sea Lev. FLOAT : 1367.9 M MSL relative to WGS84 FLOAT : -17.3 M Actual NMEA Data in Buffer : GPRMC,235311.000,A,4546.8518,N,11111.1164,W,0.00,257.09,260110,,,DI think it shows 12 satalites but 10 got a fix if I am reading it right.· Now everyone can add me to their maps [noparse]:)[/noparse]
I had some problems with the PC not seeing my propeller, I noticed the lights/leds were dim so I replaced my power supply and loaded the GPS_Float_Demo.· Yellow wire to pin 7(as per demo), Blue wire to pin 8(as per demo), black to ground, and red to +3.3V.
Jim
Pluss my readings were done from indoors, I am sure an outside reading would be more accurate. Next monday/tuesday I will try to connect this to my laptop and get a reading from outside.
Will the new model with Smart Mode still be based on the SX or will it be upgraded to the Propeller? Propeller seems like the natural progression like the Servo Controller. Although a few pins wasted on the processor, you could put a serial and parallel LCD output on the GPS board.
Best,
Jim
Duffer
Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
