PMB-648 GPS Part# 28500 - Wrong Datasheet? — Parallax Forums
Jorge PJorge P Posts: 385
edited 2010-01-28 22:18 in Accessories
I just purchased the PMB-648 GPS unit, I checked the wiring diagram that is listed on the product page and I noticed it has a different pin/wiring, its for the PMB-248...
I can't find the documentation on the PMB-648, it just takes me to the PMB-248 page...
Anyways, here is the pinout of the PMB-648
  • White wire - GND
  • Green wire - RX
  • Black wire ·- TX
  • Red wire··· - VIn
  • Blue wire···- RXD
  • Yellow wire - TXD
that is how it is listed on the GPS·board.
I am trying to connect this to the Propeller too, I am new to both GPS and the Propeller so any help would be much appreciated.
Jorge
http://WhatsAvailable.org Software and Gadgets for Windows 7.
Post Edited (Jorge P) : 1/20/2010 6:55:07 AM GMT
    edited 2010-01-20 09:39
    Jorge P - just a quick note - I've asked Chris to take a look at this post and fix the documentation.
    I had this GPS module working on my desk last week with parts from OBEX. Chris will provide some pointers for you.
    How did you buy this GPS? It's not on our web site yet but we have 500 units in stock.
  • Jorge PJorge P Posts: 385
    edited 2010-01-20 18:37
    Ken Gracey (Parallax) said...
    I actualy purchased the PMB-248 and this was sent, I assumed that the order processing dept at parallax either made a mistake, or that they were temporarily out of stock with the PMB-248.· As for you having 500 in stock, you might want to lower that to 499, turn.gif ...
    Post Edited (Jorge P) : 1/20/2010 7:12:32 PM GMT
    edited 2010-01-20 19:57
    Jorge P,
    I just checked the PMB-248 and your pin assignments are incorrect. Conecting them that way will damage the module. If you look closer you will see that those pads on the top of the PCB do not connect directly the wires in the same order below them. This is a multi-layer PCB and for whatever reason they are placed in that order on top of the PCB and it varies from the wiring of the connector. You can verify this by connecting a continuity checker to each pad and the other side to the corresponding wire to match them up. But the wiring diagram is correct.
    Best Regards,
    Chris Savage
    Parallax Engineering
    Check out the new Savage Circuits TV!
    edited 2010-01-20 21:21
    Chris Savage (Parallax) said...
    Best Regards,
    ·I should have done that, Thanks for the reminder.... I actualy had two DMM's·right next to me as I was looking at that.blush.gif
    edited 2010-01-20 22:08
    @Jorge P,
    Consider yourself fortunate - you got the latest and highest performance GPS from Parallax. I'm attaching some specs on the PMB-648 for you since the product is not for sale on-line yet. It's a SiRFStarIII chipset with tracking of 20 satellites and quick signal lock-on. We have two versions of it, too, with and without antenna. The one you have includes internal antenna with no connection for external.
    The retail price will be $30-40. I've already provided everything to WebDev to put the two new GPS products (and a nice comparison table) on our web site. Just waiting for them to finish now.
    Enjoy the PMB-648!
    Sincerely,
  • kf4ixmkf4ixm Posts: 529
    edited 2010-01-20 22:28
    @ Ken Gracey
    Will the PMB-648 support "smart mode" as well as "raw mode" like the #28146?
    edited 2010-01-20 22:35
    @Jorge P,
    Enjoy the PMB-648!
    Sincerely,
    Since I dont want anyone to fry their PMB-648 by connecting it according to the pinout I displayed in the first post, I think I should note that my first post, I·was inacurate with the wiring, and it is in-fact the same pinout/wiring colors as the PMB-246.
    edited 2010-01-20 22:41
    @kf4ixm, raw mode. There are actually two new models PMB-648 and PMB-688.
    The current 28146 product is being upgraded to use the PMB-648, however, so it will support the Smart Mode in future production runs.
    Are you using a BASIC Stamp?
    edited 2010-01-20 22:53
    @ Ken
    Yes i am, i have the bs2 and the 28146 right now. i like the smart mode function just for it's simplicity in coding. when the upgraded 28146 comes out, will it have the option with/without antenna?
    edited 2010-01-20 23:49
    We'll use the model without external antenna connection (will use internal antenna).
    I see why you want Smart Mode - much easier with the BS2.
    Ken
    edited 2010-01-27 00:02
    I finaly got around to hooking this up and testing it.
    It was extremely accurate, putting the cordinates into google maps, it put an arrow right on my car.
    Rec.:852 Ver.:852 Fail:0 (Decoded RMC:236 GGA:237 GLL:0 GSV:141 GSA:237)
      Last decoded NMEA sentence : RMC
                 GPS Data Status : Valid
             GPS Navigation Mode : Differential GPS
            Position Fix Quality : DGPS SPS, Fix Valid
      Positioning Mode Selection : Automatic 2D/3D
         Actual Positioning mode : 3D
                       Elevation :   88  61  59  25  25  17  17  13  12  11   9   9
                         Azimuth :  216  82  52 255  94 312  39 175  35 282 230 221
                 Signal Strength :   26  39  39  30  32  20  31  23  25  16  27  --
    ID of Satellites Used in Fix :   19   9  31   3  18  14  26  22  27  11
                PDOP, HDOP, VDOP :   1.4  0.8  1.1
     Day Month Year(AD) as LONGs : 26  1  2010
     UTC Hour Min. Sec. as LONGs : 23  53  11
     Latitude in degres as FLOAT : 45.78087
    Longitude in degres as FLOAT : -111.1853
    Speed Over Gnd [noparse][[/noparse]knots] FLOAT : 0
    Course Over Gnd [noparse][[/noparse]degs] FLOAT : 257.09
    Magn. Variation [noparse][[/noparse]degs] FLOAT : --.-
    Alt. at Mean Sea Lev.  FLOAT : 1367.9 M
     MSL relative to WGS84 FLOAT : -17.3 M
      Actual NMEA Data in Buffer :
    GPRMC,235311.000,A,4546.8518,N,11111.1164,W,0.00,257.09,260110,,,D
    I think it shows 12 satalites but 10 got a fix if I am reading it right.· Now everyone can add me to their maps [noparse]:)[/noparse]
    I had some problems with the PC not seeing my propeller, I noticed the lights/leds were dim so I replaced my power supply and loaded the GPS_Float_Demo.· Yellow wire to pin 7(as per demo), Blue wire to pin 8(as per demo), black to ground, and red to +3.3V.
  • hover1hover1 Posts: 1,929
    edited 2010-01-27 14:56
    Thanks for the update. That's very good news! How accurate is the reported Altitude?
    Jim
    Jorge P said...
    edited 2010-01-28 03:24
    I am not sure how high above sea level I am, but this location is in the rocky mountains. I am sure you can find out using a topigraphical map of the GPS location just to be sure. I think it is roughly 5,000 ft, using google to convert meters to feet I get 1,367.9 meters = 4,487.86089 feet. Which is fairly accurate. My town is Belgrade Mt.! Bozeman Mt. (the next town over) is 4,795 feet above sea level, Belgrade is lower in the vally so the sea level reading seems pretty accurate, but it is roughly a 300 foot differance.
    Pluss my readings were done from indoors, I am sure an outside reading would be more accurate. Next monday/tuesday I will try to connect this to my laptop and get a reading from outside.
    edited 2010-01-28 21:13
    Ken,
    Will the new model with Smart Mode still be based on the SX or will it be upgraded to the Propeller? Propeller seems like the natural progression like the Servo Controller. Although a few pins wasted on the processor, you could put a serial and parallel LCD output on the GPS board.
    Best,
    Jim
    edited 2010-01-28 21:16
    hover1 said...
    ..., you could put a serial and parallel LCD output on the GPS board.
    Best,
    Jim
    Now i like that idea, serial out to a 4x20 for lat, long, sats and elevation!!!!hop.gifidea.gifyeah.gif
  • DufferDuffer Posts: 374
    From the current "Front Page" ad at Parallax: "Up to 20 satellites for under $40 each". That seems a bit pricey,eh? 20 x $40 = $800! That's an expensive GPS! nono.gifyeah.gif I don't think I could afford even the 12 channel model at that price.
    Duffer
    Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
