LCD Display
Hello All,
I have a design based on the BS2e chip with a Parallax Serial LCD. If I were to switch to a cheaper Display(w/o Serial Board), could I still use the BS2e chip with additional code for the Display? I've seen Display's for (5 to 7) dollars and wander if the current PBASIC code would support them. If not then what chip from Parallax would and could I still use my current code?
thanks for any help
I'M STILL LEARNING SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
thanks for any help
hmlittle59
- Stephen
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv31.pdf
The one that Parallax sell have· a Hitachi HD44780 controller
I hope this helps
··Thanks for any·
Sam
Thanks, I'll look at the postings and my application is built around a 2x16 Backlit LCD from Parallax. Also you stated that the controller (Hitachi HD44780 controller) is the one that Parallax uses. I thought that it was their own board?
Thanks for the input
Howard
hmlittle59
I down loaded the Manual from the link above and it's a bit of reading and understanding. I'm will be implementing this Display in a couple of months if all goes well. I was going to switch to the 24 pin chip first but this may make more since to start with the display to learn the new coding. I'm using the BS2e now and have code in Slots (0-4) and that will be a lot of code to rework...til then thanks
thanks again
Howard
hmlittle59
