Project box laminate
I want to produce a decal of sorts to·cover the face of my project box. Does anyone know of any neat (as in trick) way of doing this? Is there any sort of vinyl laminate that can be printed on with an inkjet type printer that can then be attached to the face of a box? Looking for something rather thick as in durable. If it is as thin as paper it would easily be torn or marked.
Any ideas?
Thanks.
Don
Any ideas?
Thanks.
Don
I bet someone at a sign shop could give you some good ideas. Good luck!
Whit+
There are some laser/inkjet based alternatives, but I have not seen anything really "durable". The landscape on this is changing quickly, so you might want to look for "self laminating" products.
The other alternative would be to laser/inkjet your panel/label on readily available label stock, and then use a self adhesive clear laminate over that. Look for labels, etc, with "permanaent" adhesive. These are harder to peel off.
Another alternative is to use a paper label underneath a thin layer of lexan or plexiglass. If you want to get really fancy, you can even use translucent colors and have the panel backlit. Before the days of computer controlled systems, I did a number of industrial and model railroad control panels this way. I had a black layer of film that I cut windows in, and then put colored celophane (spelling?) on theback side. This was sandwiched between two layers of lexan, and back lit. For one of the model railroad panels, we even had individual grain of wheat bulbs behind the track sections that corresponded with train sensors. For some of the industrial (more dollars available) we actually had "photo masks" made for the opaque portions.
A little off topic, just putting out some brain storming ideas for you.
John R.
Click here to see my Nomad Build Log
That being said does anyone know of a supplier that can take artwork and produce a tough laminate stick-on? I am not sure if laminate is the correct word here but just trying to get my idea across.
http://forums.parallax.com/showthread.php?p=870799
On MS publisher I created the look I wanted and emailed them the image then just applied and cut out the holes
Mike2545
It's not the best, and you can still have bleed problems with any "gouges" that happen over time.· You also need to make sure the adhesive is at least water resistant.
John R.
Edit the thickness
Mike2545
Post Edited (Mike2545) : 1/22/2010 9:34:47 PM GMT
· Because the source is a CAD drwing, the layout is very precise.
· I've attached a simple faceplate as an example.
· Cheers,
Tom Sisk
http://www.siskconsult.com
Especially to Phil: You might be interested in knowing that you can do the same thing with a laser. I don't know if they use a different material so the plastic doesn't have a burnt appearance in the letters or if it "just works", but the guy at our local show was doing it as part of his demo. (That new hammer is looking better all the time!)
John R.
I think it's a very similar material for laser engraving, except that the top layer is a lot thinner. The catalogs for engravable materials have begun showing up in the mail. Now I know where all those employee-of-the-month plaques and company logo pen holders come from!
The only z-axis ( depth) is on-off with a small air cylinder. The different text styles come from using different texts in the CAD program and the router just makes multiple passes to get the required boldness. Same with widths of straight lines. Router bits are available from something like 0.008" up to 0.125" or perhaps a bit more. I think this one was done with 0.010".
Cheers,
Tom Sisk
Have you checked out something like myonestop.com? They are fairly cheap, but they don't offer completely clear windows.
Another option, the Brother p-touch label printer makes crisp laminated labels, in two colors with a wide variety of tapes available online. They are weather and scuff resistant. But it only makes relatively narrow labels.
Tracy Allen
www.emesystems.com
Is the ink waterproof? If so, you might try what vinyl sign installers do and wet the clear overlay in water will a little dish soap added. That makes it easy to squeegee out the air bubbles before the adhesive has a chance to grip.
I am intrigued by the laser toner method that was in Peter's method linked to above. I wonder how scuff and weather resistant that is on its own, or if the laser labels also want lamination.
Tracy Allen
www.emesystems.com
I've used the Jac polylaser labels for many years with excellent results. Weather resistance and durability is excellent. Scuffing is also much improved as the toner really seems to stick to that surface very well, at least in the HP / Lexmark printers I've used.
JAC have since been bought by someone else, not sure if they are still available. Avery have a very similar one. I bought a whole heap of samples in a couple of years ago, here's a couple of US links
www.graytex.com/waterproof-paper.htm
An interesting use for such synthetic papers is printing maps for use in underwater caving/caverning. That strikes me as a pretty good test.
Re the original question - there was someone here maybe 6 months ago using laser obliteration to make clear patches on a laminated panel. Then they overpainted the back to get an effect very similar to modern CRO panels. Anyone remember any details? I can't find the thread. I hate that...
Post Edited (Tubular) : 1/24/2010 8:18:29 AM GMT
*Peter*
I've used this trick to put 15 x 1 foot stickers on boat hulls. I was taught it years ago when I was using decals on models. A squirt gun with a bit of dish soap in the water works wonders. For whatever reason, as the water slowly dries out the dish soap just becomes inert to the adhesives. Makes bubble removal a snap. Old credit cards make great squeegees.
Life may be "too short", but it's the longest thing we ever do.
I also experimented today with using some translucent page dividers and some clear plastic file folder material. These materials are the type of material I was hoping to find. I think it is a polyester type material. I cut them into 8 1/2 x 11" pieces and tried them in my laser printer using Publisher and setting the print to be reversed and mirrored. Somewhat succesful although the toner does not fully bond to the plastic (polyester?). Looking into this further I think if one were to use a dye sublimation printer to print onto polyester type material I might really have something.
What I am also going to try is using the weatherproof label paper underneath this polyester material for durability and protection.
Does anyone have any ideas for cutting out (punching out?) holes and / or windows in this material? I used an exacto knife but a punch type device would be nicer to get a cleaner / straighter edge.
I have attached a couple photos showing the page divider material with the printing on the revese side.
Mike2545
As for holes, I avoid them, let the light shine through!. Actually, the polyester is thinner and less opaque to transmitted light than paper, so this works well to leave the led area blank. But if I do cut edges I just use a regular craft knife (Exacto type) or use a punch for holes, although it's not ideal. To make it a bit easier when cutting edges I try to use a border that is a similar color to the edge but lighter so that I can see where to cut and if it's not perfect then at least you don't have obvious white bits glaring back at you. On a black edge I use some gray around it.
Now I have done scores and scores or different labels this way and shipped live product to big customers with it too, that's how good it is. So for protos and small runs I just use this method. The OpenOffice Draw program is an ideal program to use to create the layers and objects as it's so easy to use yet by hitting F4 I can punch in exact position, size, rotation, corners etc.
I have attached a sample label in this format. I even have little labels for the keypad that blend in so well into a black keypad that they look the real deal.
*Peter*
A leather anvil punch works very well in this kind of material for small holes, if you do need them for controls or leds or screws, much cleaner than a paper punch/die.
Tracy Allen
www.emesystems.com
It works on wood, plastic and metal.
Bill
Here's some links:
http://www.office.xerox.com/printers/color-printers/phaser-8560/enus.html
http://www.ssi-electronics.com/default.aspx?pageId=2
http://www.eplastics.com/Plastic/Clear_Polyester_Film;jsessionid=0a010b421f431f41d214c1ac4b72864db56a83976e44.e3eSc38TaNqNe34Pa38Ta3aMbxf0
http://www.rshughes.com/products/021200_18408.html?ref=g&refcp=froogle
Post Edited (Don M) : 2/5/2010 2:47:34 AM GMT
I do intend to try somewhere before I buy. I will be doing a reverse print so the finished side will be protected. Thanks for your input.
