Yet Another RS232 Serial Programmer — Parallax Forums
Brian RileyBrian Riley Posts: 626
edited 2010-01-23 02:45 in Propeller 1
Several years ago, when Mark McCann and I offered the Propeller Robot Controller I took the ubiquitous 3 transistor design and put it to copper and called it the "P1". P1 works just fine. The standard kit comes out to a 5 pin socket header horizontally. The pinout matches the Prop Plug and the 5th pin located adjacent to the RX pin takes in 3-5volts.
As an added bonus the same unit can be attached to a BS2/BS2SX OEM chip and replace a bunch of circuitry for a bargain-basement priced BS2!
I sold about 200+ of them and then kind of changed focus and stopped advertising them. I have recently refocussed on the Propeller and was cleaning up the web page and taken some new pix and was going to make this posting later this weekend when I saw the SerPLug posting.
Unlike the SerPlug guys it has NOT been my experience that the design has problems with USB/RS232. I have run USB/RS232 adapters, with FTDI and with PL2303 chipsets, on Windows for the Stamp Editor and the Prop Tool with the P1 with no problem. I have also run the same chipsets with a P1 on a MacIntosh under OSX 10.6.2 with MacBS2 and BST likewise with no problem.
The P1 is offered primarily as a kit, it comes with both pin headers and socket headers so you can chose to use it on bread boards or proto boards, etc. A single kit is $5 and $2 s/h, multiple kits are cheaper. I will ship an assembled/tested unit for an additional $2. I also offer bare PCBs.
The attached photos P1-14 shows two P1's one with the Prop PLug style connector and the other with the 5 pins vertical for breadboarding. The second picture P1-15 shows the P1 in use with a Propeller Proto Board and a wire jumper from pin 5 to pickup 3.3v from the board. You can see more pictures, schematics, assembly instructions, as well as order at my website
http://www.wulfden.org/TheShoppe/pa/index.shtml#P1
The P1 is available immediately.
Cheers … BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
Post Edited (Brian Riley) : 1/23/2010 12:13:19 AM GMT
