Catalina 2.6 - a FREE C compiler for the Propeller - The Final Frontier! - Page 6 — Parallax Forums
13468920
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2010-01-21 23:09
    @ RossH
    I have got Code::Blocks·working.
    Now to get Catalina up on Ramblade SBC. What targets files require modification ?
    There is only SIO on 23..22 so maybe its only Catalina_xmm, are there others ?
    Ron
    Post Edited (Ron Sutcliffe) : 1/22/2010 12:08:18 AM GMT
    edited 2010-01-21 23:15
    Ok back in the saddle. I got version 2.3
    The first one is the same as before - flashing cursor, green background and no text
    I tried simplifying the one that works with the second option and just changed the hires vga to low res VGA and that works fine.
    So I think the problem is with linking to the hi res vga driver (or the driver itself).
    The program doesn't test the keyboard as such, but the keyboard lights are blinking on restart, so I think the keyboard is working ok too.
    I've taken a working Dracblade and popped out the propeller chip and I can send you the board. (It boots to CP/M, you might like to try programming in BDS C?!) Can you please PM me your address?
    But more to the point, once the display is working we can look at using the 512k of ram.
    Down the bottom of this thread I've posted the ram driver code. It uses the same instructions as cluso's driver, but the PASM is completely different. But very easy to use:
    OBJ
      RamLatches    : "Dracblade"                ' to talk to the ram chip
    then at the beginning
      r := RamLatches.start                                 'start the dracblade driver
    then set the high latch A16-A23 (512k uses A16 to A18, the other pins are spare)
      HighLatchByte :=%00000000_00000000_00000000_00000000 ' xxxxxxxx_nnnnnnnn_xxxxxxxx_xxxxxxxx where n is A16 to A23
      RamLatches.DoCmd("H", 0, HighLatchByte, 0)           ' set high latch byte A16-A18, plus led plus the 4 spare outputs
    then to write some bytes to a location in ram
    r := RamLatches.DoCmd("W", @buff, $FF00, 256)               'write 256 bytes from buff[noparse][[/noparse]] to sram location $FF00
    and to read some bytes from ram
    r := RamLatches.DoCmd("R", @buff, $80, 128) ' read 128 bytes from location 80H in ram to the buff array
    I hope there is a cunning way that could be useful for storing data in C
    C:\Program Files\Catalina>use_catalina
       SETTING UP CATALINA
    CATALINA_DEFINE  = [noparse][[/noparse]default]
    CATALINA_INCLUDE = [noparse][[/noparse]default]
    CATALINA_LIBRARY = [noparse][[/noparse]default]
    CATALINA_TARGET  = [noparse][[/noparse]default]
    CATALINA_LCCOPT  = [noparse][[/noparse]default]
    CATALINA_TEMPDIR = [noparse][[/noparse]default]
    LCCDIR           = [noparse][[/noparse]default]
    C:\Program Files\Catalina>catalina -D DRACBLADE hello_world.c -lc
    Catalina Compiler 2.3
    Homespun Spin Compiler 0.27
    parsing C:\Program Files\Catalina\target\lmm_default.spin
    parsing C:\Program Files\Catalina\target\Catalina.spin
    parsing C:\Program Files\Catalina\target\Catalina_Common.spin
    parsing C:\Program Files\Catalina\target\Catalina_LMM.spin
    parsing C:\Program Files\Catalina\target\Catalina_HMI_Plugin_HiRes_Vga_No_Mouse.
    spin
    parsing C:\Program Files\Catalina\target\Catalina_comboKeyboard.spin
    parsing C:\Program Files\Catalina\target\Catalina_VGA_HiRes_Text.spin
    compiling lmm_default.spin
    compiling Catalina.spin
    compiling Catalina_LMM.spin
    compiling Catalina_HMI_Plugin_HiRes_Vga_No_Mouse.spin
    compiling Catalina_comboKeyboard.spin
    compiling Catalina_VGA_HiRes_Text.spin
    compiling Catalina_Common.spin
    writing hello_world.binary
    C:\Program Files\Catalina>catalina -D DRACBLADE hello_world.c -lc -D LORES_VGA
    parsing C:\Program Files\Catalina\target\Catalina_HMI_Plugin_LoRes_Vga.spin
    parsing C:\Program Files\Catalina\target\Catalina_comboMouse.spin
    parsing C:\Program Files\Catalina\target\Catalina_mouse.spin
    parsing C:\Program Files\Catalina\target\Catalina_VGA_Text.spin
    parsing C:\Program Files\Catalina\target\vga.spin
    compiling Catalina_HMI_Plugin_LoRes_Vga.spin
    compiling Catalina_comboMouse.spin
    compiling Catalina_mouse.spin
    compiling Catalina_VGA_Text.spin
    compiling vga.spin
    Dracblade ram driver
    ''Dracblade driver for talking to a ram chip via three latches
    '' Modified code from Cluso's triblade
    ' DoCmd(command_, hub_address, ram_address, block_length)
    ' R - read bytes at address n up (n to n+block_length) where n =0 to 65535 (ie lower 64k of the sram chip)
    ' W - write bytes at address n up
    ' I - initialise
    ' N - Led on
    ' F - Led off
    ' H - set high latch to value in ramaddress A16 to A23 (will include the led)
    VAR
    ' communication params(5) between cog driver code - only "command" and "errx" are modified by the driver
       long  command, hubaddrs, ramaddrs, blocklen, errx, cog ' rendezvous between spin and assembly (can be used cog to cog)
    '        command  = R, W, N, F H =0 when operation completed by cog
    '        hubaddrs = hub address for data buffer
    '        ramaddrs = ram address for data ($0000 to $FFFF)
    '        blocklen = ram buffer length for data transfer
    '        errx     = returns =0 (false=good), else <>0 (true & error code)
    '        cog      = cog no of driver (set by spin start routine)
    PUB start : err_
    ' Initialise the Drac Ram driver. No actual changes to ram as the read/write routines handle this
      command := "I"
      cog := 1 + cognew(@tbp2_start, @command)
      if cog == 0
        err_ := $FF                 ' error = no cog
      else
        repeat while command        ' driver cog sets =0 when done
        err_ := errx                ' driver cog sets =0 if no error, else xx = error code
    PUB stop
       if cog
          cogstop(cog~ - 1)
    PUB DoCmd(command_, hub_address, ram_address, block_length) : err_
    ' Do the command: R, W, N, F, H
      hubaddrs := hub_address       ' hub address start
      ramaddrs := ram_address       ' ram address start
      blocklen := block_length      ' block length
      command  := command_          ' must be last !!
    ' Wait for command to complete and get status
    DAT
    '' | Dracblade Ram Driver (with grateful acknowlegements to Cluso)            |
                            org     0
    tbp2_start    ' setup the pointers to the hub command interface (saves execution time later
                                          '  +-- These instructions are overwritten as variables after start
    comptr                  mov     comptr, par     ' -|  hub pointer to command
    hubptr                  mov     hubptr, par     '  |  hub pointer to hub address
    ramptr                  add     hubptr, #4      '  |  hub pointer to ram address
    lenptr                  mov     ramptr, par     '  |  hub pointer to length
    errptr                  add     ramptr, #8      '  |  hub pointer to error status
    cmd                     mov     lenptr, par     '  |  command  I/R/W/G/P/Q
    hubaddr                 add     lenptr, #12     '  |  hub address
    ramaddr                 mov     errptr, par     '  |  ram address
    len                     add     errptr, #16     '  |  length
    err                     nop                     ' -+  error status returned (=0=false=good)
    ' Initialise hardware (unlike the triblade, just tristates everything and read/write set the pins)
    init                    mov     err, #0                  ' reset err=false=good
                            mov     dira,zero                ' tristate the pins
    done                    wrlong  err, errptr             ' status  =0=false=good, else error x
                            wrlong  zero, comptr            ' command =0 (done)
    ' wait for a command (pause short time to reduce power)
    pause                   mov     ctr, delay      wz      ' if =0 no pause
                  if_nz     add     ctr, cnt
                  if_nz     waitcnt ctr, #0                 ' wait for a short time (reduces power)
                            rdlong  cmd, comptr     wz      ' command ?
                  if_z      jmp     #pause                  ' not yet
    ' decode command
                            cmp     cmd, #"R"       wz      ' R = read block
                  if_z      jmp     #rdblock
                            cmp     cmd, #"W"       wz      ' W = write block
                  if_z      jmp     #wrblock
                            cmp     cmd, #"N"       wz      ' N= led on
                  if_z      jmp     #led_turn_on
                            cmp     cmd, #"F"       wz      ' F = led off
                  if_z      jmp     #led_turn_off
                            cmp     cmd, #"H"       wz      ' H sets the high latch
                  if_z      jmp     #sethighlatch
                            mov     err, cmd                ' error = cmd (unknown command)
                            jmp     #done
    tristate                mov     dira,zero                ' all inputs to zero
                            jmp     #done
    ' turn led on
    led_turn_on             or      HighLatch,ledpin        ' set the led pin high
                            jmp     #OutputHighLatch         ' send this out
    led_turn_off            andn    HighLatch,ledpin        ' set the led pin low
    ' set high address bytes with command H, pass value in third variable of the DoCmd
    ' 4 bytes - masks off all but bits 16 to 23
    sethighlatch            call #ram_open                  ' gets address value in 'address'
                            shr  address,#16                ' shift right by 16 places
                            and  address,#$FF               ' ensure rest of bits zero
                            mov  HighLatch,address          ' put value into HighLatch
                            jmp  #OutputHighLatch           ' and output it
    'Memory Access Functions
    rdblock                 call    #ram_open               ' get variables from hub variables
    rdloop                  call    #read_memory_byte       ' read byte from address into data_8
                            wrbyte  data_8,hubaddr          ' write data_8 to hubaddr ie copy byte to hub
                            add     hubaddr,#1              ' add 1 to hub address
                            add     address,#1              ' add 1 to ram address
                            djnz    len,#rdloop             ' loop until done
                            jmp     #init                   ' reinitialise
    wrblock                 call    #ram_open
    wrloop                  rdbyte  data_8, hubaddr         ' copy byte from hub
                            call    #write_memory_byte      ' write byte from data_8 to address
                            djnz    len,#wrloop             ' loop until done
    ram_open                rdlong  hubaddr, hubptr         ' get hub address
                            rdlong  ramaddr, ramptr         ' get ram address
                            rdlong  len, lenptr             ' get length
                            mov     err, #5                 ' err=5
                            mov     address,ramaddr         ' cluso's variable 'ramaddr' to dracblade variable 'address'
    ram_open_ret            ret
    read_memory_byte        call #RamAddress                ' sets up the latches with the correct ram address
                            mov dira,LatchDirection2        ' for reads so P0-P7 tristate till do read
                            mov outa,GateHigh               ' actually ReadEnable but they are the same
                            andn outa,GateHigh              ' set gate low
                            nop                             ' short delay to stabilise
                            nop
                            mov data_8, ina                 ' read SRAM
                            and data_8, #$FF                ' extract 8 bits
                            or  outa,GateHigh               ' set the gate high again
    read_memory_byte_ret    ret
    write_memory_byte       call #RamAddress                ' sets up the latches with the correct ram address
                            mov outx,data_8                 ' get the byte to output
                            and outx, #$FF                  ' ensure upper bytes=0
                            or outx,WriteEnable             ' or with correct 138 address
                            mov outa,outx                   ' send it out
                            nop                             ' no nop doesn't work, one does, so put in two to be sure
                            nop                             ' another NOP
                            or outa,GateHigh                ' set it high again
    write_memory_byte_ret   ret
    RamAddress ' sets up the ram latches. Assumes high latch A16-A18 low so only accesses 64k of ram
                            mov dira,LatchDirection         ' set up the pins for programming latch chips
                            mov outx,address                ' get the address into a temp variable
                            and outx,#$FF                   ' mask the low byte
                            or  outx,LowAddress             ' or with 138 low address
                                                            ' ?? a NOP
                                                            ' now repeat for the middle byte
                            shr outx,#8                     ' shift right by 8 places
                            or  outx,MiddleAddress          ' or with 138 middle address
    RamAddress_ret          ret
    OutputHighLatch ' sends out HighLatch to the 374 that does A16-19, led and the 4 spare outputs
                            mov     dira,latchdirection     ' setup active pins 138 and bus
                            mov     outa,HighLatch          ' send out HighLatch
                            or      outa,HighAddress        ' or with the high address
    OutputHighLatch_ret     jmp     #tristate               ' set pins tristate
    delay                   long    80                                    ' waitcnt delay to reduce power (#80 = 1uS approx)
    ctr                     long    0                                     ' used to pause execution (lower power use) & byte counter
    GateHigh                long    %00000000_00000000_00000001_00000000  ' HC138 gate high, all others must be low
    Outx                    long    0                                     ' for temp use, same as n in the spin code
    LatchDirection          long    %00000000_00000000_00001111_11111111 ' 138 active, gate active and 8 data lines active
    LatchDirection2         long    %00000000_00000000_00001111_00000000 ' for reads so data lines are tristate till the read
    LowAddress              long    %00000000_00000000_00000101_00000000 ' low address latch = xxxx010x and gate high xxxxxxx1
    MiddleAddress           long    %00000000_00000000_00000111_00000000 ' middle address latch = xxxx011x and gate high xxxxxxx1
    HighAddress             long    %00000000_00000000_00001001_00000000 ' high address latch = xxxx100x and gate high xxxxxxx1
    'ReadEnable long    %00000000_00000000_00000001_00000000 ' /RD = xxxx000x and gate high xxxxxxx1
                                                            ' commented out as the same as GateHigh
    WriteEnable             long    %00000000_00000000_00000011_00000000 ' /WE = xxxx001x and gate high xxxxxxx1
    Zero                    long    %00000000_00000000_00000000_00000000 ' for tristating all pins
    data_8                  long    %00000000_00000000_00000000_00000000 ' so code compatability with zicog driver
    address                 long    %00000000_00000000_00000000_00000000 ' address for ram chip
    ledpin                  long    %00000000_00000000_00000000_00001000 ' to turn on led
    HighLatch               long    %00000000_00000000_00000000_00000000 ' static value for the 374 latch that does the led, hA16-A19 and the other 4 outputs
    Post Edited (Dr_Acula) : 1/21/2010 11:20:47 PM GMT
  • RossHRossH Posts: 5,704
    edited 2010-01-22 00:03
    @Ron,
    I suggest you download and have a look at the DracBlade support package - it contains all the files that might need to be changed, and if you search for 'DRACBLADE' you will see every change I had to make for that board (including XMM changes, even though the XMM code itself hasn't been written yet). You can model your RamBlade changes on that. Mostly it's changing the pin configurations and the choice of drivers to use in various circumstances (e.g. on the RamBlade you will probably want to default to the PC drivers for display and keyboard).
    I won't get time to do this myself till at least next week, but if you can wait that long I'll include both RamBlade and DracBlade support in a Catalina patch release (at least LMM support - for XMM support I'll either need a RamBlade board, or rely on Cluso or yourself to write the XMM code).
    I have finally managed to fix the Catalina program loader and want to get that out this week - then I have a backlog of work to do to support Bob Anderson's new C source level debugger (woohoo!).
    Ross.
    edited 2010-01-22 00:05
    @Dr_Acula,
    PM sent.
    The next program you might want to try is probably 'test_suite.c' - this is a trivial program that test a few simple C features (and also uses the keyboard).
    Ross.
    edited 2010-01-22 00:48
    Test_suite.c works brilliantly. LORES_VGA is fine for the moment. (see picture at bottom of post)
    And I must say that this little program is a really good introduction to C. It is very helpful to see real world simple examples of code.
    I wrote a tiny batch file with a simple name so I can compile quickly. Called it TS.BAT and it contains
    catalina -D DRACBLADE test_suite.c -lc -D LORES_VGA
    So now the edit/download/re-edit/download cycle is down to only 5 seconds. That makes development fun!
    I wonder if you might be interested in adding in the LCD code? No hurry as I know other things are higher priority, but this is one of the nifty things about the dracblade - you don't need a VGA or TV if you don't want to. For small projects you can do a lot with a 20x4LCD (or even smaller ones), especially if you keep the questions and answers short
    enter your name:
    enter your age:
    etc
    With CP/M the output goes to vga, to LCD and to the serial port and hence a terminal program, so you can use all three if you want.
    PUB PrintChar(c) ' sends c to the uart, LCD display and the vga display
        UART.tx(0,c)                                  ' send to the PC
        LCD.out(c)                                    ' send to LCD display
        vgatext.txVT100(c)                            ' send to vt100 terminal
    The LCD driver is pretty straightforward. But I'm not sure how catalina includes things like optional code. Is it with #ifdefs like the zicog does?
    '' parallel 20x4 lcd driver for the DracBlade including a 'Terminal' that scrolls properly, backspace etc
    CON
      _clkmode      = xtal1 + pll16x                        ' use crystal x 16
      _xinfreq      = 5_000_000
      LatchDirection =%00000000_00000000_00001111_11111111 ' 138 active, gate active and 8 data lines active
      MaskLowByte =   %00000000_00000000_00000000_11111111 ' used in lots of routines to & mask off low byte
      LCDLatch =      %00000000_00000000_00001011_00000000 ' LCD latch is xxxx101x and gate high xxxxxxx1
      EnableBit =     %00000000_00000000_00000000_00000010 ' Enable pin 6 on LCD displays
    OBJ
     delay    : "timing"
    VAR
    long Char                       ' Character To Send To LCD
    long Inst                       ' Instuction To Send To LCD
    long Column                     ' column counter for line 4 ' don't use byte, causes all sorts of overrun errors
    long LineNumber                 ' line number 1,2,3,4
    long LCDChar                    ' character to send to LCD 0-$FF
    long LCDByte                    ' byte to latch out to LCD display
    byte Display[noparse][[/noparse]79]                ' buffer for display 20x4  ' put this last as bizarre overwriting going on
    PUB Start  | n
        Init_Lcd
        Column:=0                                           ' start at zero
        repeat n from 0 to 79                ' fill the display memory with spaces
          Display[noparse][[/noparse]n]:=" "         'fill with spaces
        Redraw
        repeat 25        ' test code for running standalone
          out(65)
        out(10)
        out(66)
        out(13)
    PUB str(stringptr)
    '' Print a zero-terminated string
      repeat strsize(stringptr)
        out(byte[noparse][[/noparse]stringptr++])
    PUB dec(value) | i '' Print a decimal number
      if value < 0
        -value
        out("-")
      i := 1_000_000_000
      repeat 10
        if value => i
          out(value / i + "0")
          value //= i
          result~~
        elseif result or i == 1
          out("0")
        i /= 10
    PUB hex(value, digits) '' Print a hexadecimal number
      value <<= (8 - digits) << 2
      repeat digits
        out(lookupz((value <-= 4) & $F : "0".."9", "A".."F"))
    PUB bin(value, digits)
    '' Print a binary number
      value <<= 32 - digits
      repeat digits
        out((value <-= 1) & 1 + "0")
    PUB out(c) | i,j
    ' Output a character, ignores most <32 and all >126
    ' possibly add a 'turn on display' and 'turn off display' with selected ascii characters ?? esc seq
        i:=c ' need a local working variable as an if statement seems to corrupt subsequent working variables!
        j:=Column ' and need a local version of column otherwise corrupts this too
        if c==10                                              ' Linefeed
            Newline
            Column:=0                                           ' reset column counter
            j:=21                                               ' ensures code below doesn't run
        if j<20 ' this LCD driver code is slow so better to not print anything after line 20 and wait for CRLF
    '    if j > 19                                      ' is it off the end of the display? (old display wrapped around)
    '      Column:=0                                         ' reset to beginning
    '      Newline
          if c==08                                              ' Backspace
            Backspace
    '      if c==13                                              ' do nothing as LF includes CR as part of the code
          if i >= 31                                              ' and statements don't work in if lines?!
            if i<=126                                             ' send the ascii character
              char := c                                           ' get the character
              Send_Text                                           ' send it out
              Display[noparse][[/noparse]Column+60]:=c                                  ' store the character in the last column
              Column:=Column+1                                    ' add 1 to column
         if j==19
            CursorOff
    PUB CursorOn
      Inst:=13                                              ' turn on the cursor
      Send_Inst
    PUB CursorOff
      Inst:=12                                          ' cursor off
      Send_Inst                                         ' send the instruction
    PRI  Init_Lcd
        LCDLow                                              ' set the 6 LCD lines low
        delay.pause1ms(200)                                 ' short delay for LCD bootup 200ms
        LCDByte:=%00001100                                  ' send out 0011 already shifted to xxnnnnxx
        PulsOut
        PulsOut
        PulsOut
        LCDByte:=%00001000                                  ' send out 0010 already shifted to xxnnnnxx
        PulsOut
        PulsOut
        LCDByte:=%00100000                                  ' send out 1000 already shifted to xxnnnnxx
        PulsOut
        Inst:=14                                            ' cursor on
        Send_Inst
        Inst:=1                                             ' cls
        Send_Inst
        Inst:=13                                            ' flashing cursor
        Send_Inst
        Inst:=128                                           ' to position 1
        Send_Inst
    pri Send_Inst ' send instruction in Inst
        RSLow                                                      ' not actually needed see below but makes code more logical
        LCDByte:=Inst                                              ' get high nibble
        LCDByte:=LCDByte>>2                                        ' shift right two bits so xxnnnn00
        LCDByte:=LCDByte & %00111100                               ' mask the nibble and sets RS low as well (bit0)
        Pulsout                                                    ' send it out
        LCDByte:=Inst                                              ' get low nibble
        LCDByte:=LCDByte<<2                                        ' shift left two bits so xxnnnn00
        RSHigh                                                     ' back to text mode
    pri Send_Text ' pass Char = a byte
       'RS always high = bit 0, bits are xxnnnnER where nnnn is the nibble, E=enable and R=RS
       LCDByte:=Char
       LCDByte:=LCDByte & %00111100                         ' mask off just the nibble
       LCDByte:=LCDByte | %00000001                         ' keep RS high
       LCDByte:=Char                                        ' get low nibble
       Pulsout
    pub Next_Line
        Inst := %11000000                         ' Move Cursor To Line 2
        Send_Inst
    PRI ToggleGate
       OUTA[noparse][[/noparse]8]:=0                                            ' set gate pin low
       OUTA[noparse][[/noparse]8]:=1                                            ' and high again - may need a delay in PASM
    PRI EnableLatchPins
        DIRA:=LatchDirection                                ' 138 active, gate active and 8 data lines active
    PRI Tristate ' tristate all pins
      DIRA:=%00000000_00000000_00000000_00000000
    PUB LCDOutput | n ' sends byte LCDByte to latch
       EnableLatchPins ' turn on the pins needed to talk to the latches
       n:=LCDByte                                           ' byte value to send out
       n:=(n & MaskLowByte)                                 ' 2 AND mask the low byte
       n:=(n | LCDLatch  )                                  ' 3 OR with the LCD address 138
       OUTA:=n                                              ' 4 send it out
       ToggleGate                                           ' 5 and latch it
       tristate ' back to tristate on all pins
    PUB LCDLow ' sets all LCD pins low for startup
       LCDByte:=0
       LCDOutput
    PUB PulsOut ' pulse the enable pin 6 high then low - uses LCDByte and returns it unchanged
       LCDByte:=(LCDByte | %00000010)                       ' logical OR  to set just this bit high
       LCDOutput                                            ' send it out
    '   delay.pause1ms(1)                                    ' short pause not needed as spin very fast
       LCDByte:=(LCDByte & %11111101)                       ' logical AND set just this bit low
    '   delay.pause1ms(1)                                    ' delay for LCD to process it
    PUB RSHigh  ' set RS pin 4 high - uses LCDByte and returns it unchanged
       LCDByte:=(LCDByte | %00000001)                       ' logical OR  to set just this bit high
       LCDOutput
    PUB RSLow ' set RS pin 4 low - uses LCDByte and returns it unchanged
       LCDByte:=(LCDByte & %11111110)                       ' logical AND set just this bit low
       LCDOutput
    PUB Backspace | i,j
    ' backspace is a special case - need to subtract 1 off the column, make the last character a space
    ' and redraw the screen and print out column number of characters on last line
    ' only really works on line 4 but most of the time the display is on line 4 anyway
        j:=Column                 ' the last character added 1 to column so start with one less
        if j>1                      ' not reliable at 1
          Display[noparse][[/noparse]Column+60-1]:=32    ' was one past the character
          Column:=Column-1            ' subtract 1
          Redraw
          repeat i from 0 to j-2
            Char:=Display[noparse][[/noparse]60+i]        ' print out the last row with one less character
            Send_Text
    PUB Redraw                        ' redraw the entire screen
        Inst:=128                     ' line 1
        Send_Inst
        LineNumber:=1                 ' print line 1
        Printline
        Inst:=192                     ' line 2
        Send_Inst
        LineNumber:=2                 ' print line 2
        Printline
        Inst:=148                     ' line 3
        Send_Inst
        LineNumber:=3                 ' print line 3
        Printline
        Inst:=212                     ' line 4
        Send_Inst
        LineNumber:=4                 ' print line 4
        Printline
        Inst:=212                     ' cursor to beginning of line 4
        Send_Inst
        CursorOn
    PUB PrintLine | n                   ' Prints the line in LineNumber 1 to 4
        n:=(LineNumber-1)*20                ' convert to pointer for the array 0-79
        repeat 20                       ' do this 20 times
          Char:=Display[noparse][[/noparse]n]              ' get the character from the array
          n:=n+1                        ' increment counter
    PUB Newline | i ' move the lines all up one, clear line 4, move cursor to position 1 of line 4
        repeat i from 0 to 59                                            ' move up to next line
          Display[i]:=Display[noparse][[/noparse]i+20]
        repeat i from 60 to 79
          Display[i]:=32                                    ' space
        Column:=0                                           ' column counter to zero
        Redraw                                              ' redraw the screen
    [/i][/i]
    Post Edited (Dr_Acula) : 1/22/2010 12:57:33 AM GMT
    1280 x 960 - 259K
    edited 2010-01-22 02:22
    @Dr_Acula,
    Glad you got it working. I'll figure out what's going wrong with the hires VGA driver when I get some time.
    The LCD code would make a very useful debugging aide - no promises, but I'll see what I can do. The simplest way to add support for it in Catalina would be to just add it as another alternative HMI option (e.g. if you compile a program with '-D LCD' standard output (stdout) would become the LCD). The problem with this is that you couldn't use both VGA and LCD at the same time.
    A more complex (but more useful) solution would be to make the VGA display the C standard output (stdout) but have the LCD display the C standard error output (stderr) - this would fit in very well with using it as a debugging aide. However, this would require a custom DracBlade VGA driver, as currently both stdout and stderr go to the VGA display (but using separately addressable cursors so you can put them at different places on the screen).
    Ross.
    edited 2010-01-22 13:40
    @all,
    Just released a small patch to fix a bug in the Catalina Generic SD/SIO Program Loader. The patch is attached to the first post in this thread. Here are the details:
    Patch Release 22 Jan 10
    This release contains a small patch to fix a bug in the Catalina Generic SD and SIO Loaders which could lead to programs failing to initialize correctly - typical symptoms were that the screen was cleared, but the C program was never started (especially when using the HiRes TV driver). It appears that clearing unused hub RAM to zero is required whenever a new program is loaded, or the SPIN interpreter may not start correctly.
    Just apply this patch over Release 2.3 and run 'rebuild_all' in the utilities directory to rebuild the loader binaries - no need to rebuild Catalina.
    Ross.
    edited 2010-01-23 04:52
    @Dr_Acula,
    I just noticed a difference between your version of the HiRes VGA text driver (VGA_HiRes_Text.spin) and my version modified for Catalina (Catalina_VGA_HiRes_Text.spin).
    I had assumed my version was based on Chip's original, but I found a difference I can't account for:
    My version:
    movi    frqa,#(pr<<2 / 5)     'set pixel rate
    Your version (and also the version in the OBEX):
    movi    frqa,#(pr / 5) << 2     'set pixel rate
    When I use your version it no longer works on my Hydra. I don't remember making this change, so I think the Hydra must have come with a customized version and I didn't realize it.
    I have enclosed a new version (modified for Catalina) based on the OBEX original. Can you try it out for me? Please copy the enclosed file to the Catalina target directory and recompile 'hello_world.c' using the following command:
    Ross.
    Edit: attachment removed. DracBlade support is now part of the main Catalina release.
    Post Edited (RossH) : 1/28/2010 10:40:01 AM GMT
    edited 2010-01-25 11:02
    I've lost the vibe somehow.
    Ok, new hires to c:\program files\catalina\target
    Microsoft Windows XP [noparse][[/noparse]Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Administrator>cd c:\program files\catalina
       SETTING UP CATALINA
    spin
    and I still get pale green cursor on dark green screen.
    There will be one tiny thing I'm not doing right...
    edited 2010-01-25 11:06
    @Dr_Acula,
    It was a long shot, but worth a try - I'll figure out what the problem is when your board arrives.
    Ross.
    edited 2010-01-28 10:36
    @All,
    I have just released a small patch to Catalina - it is attached (as usual) to the first post in this thread. Here are the details:
    Patch Release 28 Jan 10
    This release is a small patch to fix a bug in the Catalina HiRes VGA Driver when used with the NO_MOUSE option, or on a platform without a mouse (such as the DracBlade). It also adds support for the DracBlade (there are no XMM drivers for the DracBlade yet, but LMM and EMM programs will now work correctly).
    Just unzip the patch in the zipfile attached to this post over a Catalina Release 2.3 installation and rebuild any affected C programs - no need to rebuild Catalina.
    Ross.
    edited 2010-01-28 20:39
    @All,
    Just updated the Patch Release 28 Jan 10 - the original zip file had the wrong folder names, and unzipping it over your exisitng Catalina installation would have simply created a 'Catalina_Patch_28_Jan_10" folder - you can either download the zip file again, or manually copy everything out of that folder up one level (i.e. into the main Catalina directory).
    Sorry about that!
    Ross.
    edited 2010-01-29 13:13
    Woot! Got Othello working on the Dracblade. And other little programs as well. (@Rossh, no damage done by the patches, all was fixed with a Windows reboot rather than my usual hibernate/unhibernate. Windows needs a real reboot now and then).
    Minor problem - still bright green on dark green background.
    Ok, can you explain how to write a C program for a CP/M old timer like me?
    In CP/M the screen is whatever physical color it happens to be. Green on black, white on blue, etc. But you can change it if you want. Either with a call to some I/O ports, or with some VT100 codes. Those calls are usually the first thing in a program, right before the CLS clear screen and they are then followed by the text.
    But a Catalina program seems to leap straight into printing out text:
    Beginning C, Third Edition
     By Ivor Horton
     ISBN: 1-59059-253-0
     Published: Apr 2004
     Publisher: apress
    #include <stdio.h>
    #include <catalina_hmi.h>
    #include <ctype.h>
    #define SIZE 8  /* Board size - must be even */
    /* Function prototypes */
    void display(char board[noparse][[/noparse]][noparse][[/noparse]SIZE]);
    int valid_moves(char board[noparse][[/noparse]][noparse][[/noparse]SIZE], int moves[noparse][[/noparse]][noparse][[/noparse]SIZE], char player);
    void make_move(char board[noparse][[/noparse]][noparse][[/noparse]SIZE], int row, int col, char player);
    void computer_move(char board[noparse][[/noparse]][noparse][[/noparse]SIZE], int moves[noparse][[/noparse]][noparse][[/noparse]SIZE], char player);
    int best_move(char board[noparse][[/noparse]][noparse][[/noparse]SIZE], int moves[noparse][[/noparse]][noparse][[/noparse]SIZE], char player);
    int get_score(char board[noparse][[/noparse]][noparse][[/noparse]SIZE], char player);
    void main()
      char board [noparse][[/noparse]SIZE][noparse][[/noparse]SIZE] = { 0 };  /* The board           */
      int moves[noparse][[/noparse]SIZE][noparse][[/noparse]SIZE] = { 0 };    /* Valid moves         */
      int row = 0;                      /* Board row index     */
      int col = 0;                      /* Board column index  */
      int no_of_games = 0;              /* Number of games     */
      int no_of_moves = 0;              /* Count of moves      */
      int invalid_moves = 0;            /* Invalid move count  */
      int comp_score = 0;               /* Computer score      */
      int user_score = 0;               /* Player score        */
      char y = 0;                       /* Column letter       */
      int x = 0;                        /* Row number          */
      char again = 0;                   /* Replay choice input */
      int player = 0;                   /* Player indicator    */
      t_string(1,"\nREVERSI\n\n");
      t_string(1,"You can go first on the first game, then we will take turns.\n");
      t_string(1,"   You will be white - (O)\n   I will be black   - (@).\n");
    There probably is a way of defining screen colors within the program itself - for the dracblade it would be some OUT commands or VT100 escape commands.
    But I think Catalina defines it somewhere else. Looking at the vga driver code, I think the variables are passed via this line
    PUB start(BasePin, ScreenPtr, ColorPtr, CursorPtr, SyncPtr, FontPtr) : okay | i, j
    (the Dracblade CP/M emulation is using the same original VGA driver so I know my way around this one!)
    But what is setting ColorPtr? Is it set somehow with the command -D DRACBLADE
    And if so, is DRACBLADE a file somewhere or is it a series of switches in another source file?
    Anyway, at least we can play some games with Catalina on the Dracblade. Please forgive me if I don't post for a while *grin*
    edited 2010-01-29 14:15
    @Dr_Acula,
    Great news! I thought for a horrible moment Catalina had destroyed your PC!
    The bright green characters on a dark green background is my default color scheme for HiRes VGA. It is set up in the HMI plugin (in this case Catalina_HMI_Plugin_HiRes_Vga_No_Mouse_Input.spin - on or about line 365).
    You can also change colours from within the C program by using low level Catalina HMI functions. I have enclosed an example. Compile it with
    catalina -D DRACBLADE -lc hello_colour.c
    You could add the set_screen_color function in this program to other programs. such as the the othello.c program (and call it at the beginning of the main routine). Note that this function is specific to the HiResVGA driver - the LoResVGA uses different colors and you have to set the value of each character cell individually. One day I will write some simple "wrapper" functions that make this easier to do - so much to do, so little time!
    And DRACBLADE is just a symbol used in various #define statements spread throughout the target directory files - it just causes the DracBlade specific sections of code to be included during the compilation process.
    Ross.
    Post Edited (RossH) : 1/29/2010 2:27:15 PM GMT
    edited 2010-01-29 23:37
    This is fun!
    Ok, I edited that hmi driver
    #ifdef PROXY_SCREEN
    #else
      ' set up colors
      repeat i from 0 to rows - 1
        ' word[noparse][[/noparse]pscreen][noparse][[/noparse]colors + i] := %%0100_1310           ' pale green on dark green
        word[noparse][[/noparse]pscreen][noparse][[/noparse]colors + i] :=  %00001000_11111100  ' white on blue
    However, it hasn't changed anything.
    1) is %% octal or something - and hence is my binary code correct?
    2) Reading the ifdef, I think the above is only called if PROXY_SCREEN is false? What is proxy_screen, and if I'm not adding it to the command line, maybe it is false, and hence is the color definition coming from anywhere else in the code?
    Alright, I'm going crazy here. I saved that change and then went to find the file I had edited. Because the names are all so similar for those drivers, I went and resorted the directory based on when the files were last modified. A huge number had been edited at the same time - which was the time I did the last .c program compile. I figured - this is odd, only writing a windows file changes the edit time, not a read and a compiler should just be reading. So I went back to check my changes and they had gone.
    So to really test this out I edited out the lines above using the propeller tool and recompiled a .c program. The lines are back again!
    Are the spin source files self modifying or something? How do you make changes to them, or are you not supposed to?
    BUT ... maybe it doesn't matter, because hello_colour.c works fine, and so it would be much easier just to add these lines of code at the beginning of a program. See photo.
    Post Edited (Dr_Acula) : 1/29/2010 11:45:37 PM GMT
    1280 x 960 - 244K
    edited 2010-01-30 00:11
    @Dr_Acula,
    Your change looks fine - I just tried it here and it works. But you are not editing the correct file (yes, they are self-modifying!). You have to edit Catalina_HMI_Plugin_HiRes_Vga_No_Mouse_Input.spin in the directory C:\Program Files\Catalina\target\input\. Make sure it has the _Input in the filename - you are probably editing the version in the target directory instead - and the compiler rebuilds this version on every compile from the input files. I realize this is a bit obscure - but it is documented in various places, including at the top of the file itself.
    The %% in SPIN means 'Quaternary' - each digit is 0..3, representing 2 bits. See the Prop manual for more details.
    PROXY_SCREEN is only relevant for multi-CPU Prop systems - it allows a program running on one CPU to use a display connected to another CPU. It's used on the TriBladeProp or Morpheus, but is not relevant for the DracBlade.
    Ross.
    edited 2010-01-30 05:40
    Thanks for the clarification - now it makes a lot more sense.
    The little colour.c program is about as simple as it gets - very easy to understand and use.
    At the beginning of this thread is mention of code::blocks. Is this an IDE for catalina? I got a bit confused about the IDE option - is it possible to write and compile a C program from within one IDE type environment (similar to the prop tool)?
    edited 2010-01-30 06:27
    @Dr_Acula,
    Yes, Code::Blocks is a really cool compiler-independent graphical development environment. It's a little like the Parallax Propeller tool, but actually more similar in look and feel to Visual Studio, or to the Embedded Workbench (which many AVR users will be familiar with).
    It provides a front-end to the Catalina command line compiler - and for most programs you will never need to open a DOS window at all. Once you set up a Code::Blocks project with the appropriate configuration, it's one-click to recompile.
    Currrently you can create, edit and compile C programs with Code::Blocks. Soon you will also be able to download and debug them. The built-in editor is C syntax-aware and context-sensitive. It also has a built in 'make' function for maintaining programs that consist of multiple C source files.
    In the current release, setting up Code::Blocks is a little tricky - you have to donwload Codde::Blocks, install it, run it once, and then edit its configuration files it creates to make it 'Catalina-aware'. This is all documented in the README.codeblocks file in the codeblocks subdirectory. In future I'll try and streamline the install process.
    Ross.
    edited 2010-01-30 13:22
    Ok, got codeblocks. Reading through the install notes and configuring it at the moment. It looks very interesting. Nice to be working in an environment with colour highlighting of keywords etc. This will make it easier to spot syntax errors etc.
    I've just been reading through memory models en.wikipedia.org/wiki/C_memory_model
    The paging system of the IBM with its overlapping offsets is going to be a bit different, but paging ought to fit nicely with a 512k model. I think this is a far pointer ie up to 1 megabyte.
    Memory models are the one thing that C has that is simply not present in Basic (as far as I know). Versions of Basic were stuck with the memory of the machine they were designed for, but C seems to have worked out a model in the mid 1980s that meant it was much more machine independent.
    edited 2010-01-30 22:14
    Hi Dr_Acula,
    The page you refer to is fairly specific to machines with 16 bit architectures (such as the x86). Catalina implements it's own memory models, tailored to the Prop's true 32 bit architecture (but peculiar memory arrangement).
    All the Catalina memory models use "flat" 32 bit addresses (i.e. no segmentation). Even if the XMM hardware implements physical memory using multiple pages (for speed, or to save pins), this is hidden from the C program by the XMM access routines (such routines have not yet been written for the DracBlade, but the same will be true for those as well).
    The Catalina memory models currently implemented are:
    • Tiny. In this mode, all addresses are Hub RAM addresses – this means that all code, data, stack and heap must fit into the 32k (Prop I) or 256k (Prop II) Hub RAM. This is the mode implemented by the LMM Kernel for all programs compiled using the –x0 or –x1 command line options. It can be used on any Propeller.
    • Small. In this mode, all data addresses are Hub RAM addresses, but all code addresses are XMM RAM addresses. Currently, I only use 24 bits as XMM address since I can't imagine anyone needing more than 16Mb on a single Prop (famous last words!). All data, stack and heap must fit into the 32k (Prop I) or 256k (Prop II) Hub RAM, but code size can be up to 16Mb. This mode is implemented by the XMM Kernel, for programs compiled using the –x2 command line option. Of course, this mode requires external XMM RAM.
    • Large. In this mode, global data and code addresses are XMM addresses, and so the total code and global data (including heap) size can be up to 16Mb. The 32k (Prop I) or 256k (Prop II) of Hub RAM is used for the stack and for local data. This mode is also implemented by the XMM Kernel, for programs compiled using the –x5 command line option. Of course, this mode also requires external XMM RAM.
    More detail can be found in the Catalina Reference Manual (pp 66).
    Ross.
    edited 2010-02-03 23:08
    A couple of intriguing posts by RossH in two other threads. First - in the Dracblade thread regarding LMM working up to 512k with a promise of some code coming soon. And second,a post in a discussion about LMM by Bean with some code to do virtual Call. This I find interesting, because while I don't fully understand what a LMM actually is, what I do understand is the code to do a virtual call, because this (to me) suggests that this isn't just using the larger ram for storing data arrays, but rather it is using the larger ram to actually store program code.
    So - a question for Ross - is it now possible to use Catalina to write BIG programs in C?
    edited 2010-02-03 23:46
    Jumping in...
    YES!
    Currently Catalina supports as much as the XMM target can give... so you could use the 512KB on your board for code and data!
    One of the Blade's on TriBlade can support 1MB
    Morpheus supports 16MB, 2.5MB has been tested
    Dr_Acula said...
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-02-04 00:17
    Hi Dr_Acula,
    Yes, as Bill mentions above, instead of a measly 496 instructions, LMM allows a PASM program to be up to 8198 instructions, or use up to 32Kb of data (up to the maximum 32Kb of Hub RAM), and XMM allows PASM programs to be up to 4,194,304 instructions, or use up to 16Mb of data (up to the maximum size of the physical XMM RAM installed).
    There are a few restrictions on which PASM instructions you can use - but Catalina takes care of all that for you.
    LMM will work on ANY Propeller - it's like having a Prop with a cog size of up to 8192 longs instead of 496 longs (but running a bit slower).
    XMM will work on the Hydra, Hybrid, TriBladeProp, or Morpheus - and now on the DracBlade. It's like having a Prop with a cog size of 4 million longs (but running slower still).
    I'll post the new DracBlade target support package tonight.
    Ross.
    edited 2010-02-04 12:16
    @All,
    I have just released a small patch to add XMM support for the DracBlade. The DracBlade is now fully integrated into the standard Catalina target support package.
    See the first post in this thread for more details.
    Ross.
    edited 2010-02-04 13:14
    And the practical upshot of that is you can take a C program that compiles to a 350k binary and run it on a Propeller. Of course, Ross has done a lot of work behind the scenes to make that happen, but it all works perfectly. See the Dracblade thread posts from today.
    This really does open up some possibilities for coding huge programs.
  • normdotynormdoty Posts: 1
    edited 2010-02-07 16:23
    hey people
    ive gone over this posting 3 times and still cant find where to download the catalina compiler?
    the 3 patches, no problem, but not the base program?
    any ideas how my fading light keeps missing this?
    thanks, norm
  • mwalimumwalimu Posts: 44
    edited 2010-02-07 16:56
    "hey people
    thanks, norm"
    Um...yeah. Every link to calalina sends me back to the top of this thread. I'm not an idiot, but I'm not Sherlock Holmes either.
    edited 2010-02-07 20:46
    Hi mwalimu, normdoty
    They are in the second to sixth posts in the thread (depending on your platform - there are linux and windows versions, source and binary releases).
    In all cases you should download the documents, utilities and demos zips, and then the binary release zips for your platform. The source release zips are optional. After installing the base releases (source and/or binary) then apply the patch releases.
    Holler if you have problems.
    Ross.
    edited 2010-02-07 21:43
    Hey Ross,
    I DID figure it out. It took all morning, but I did (two hours spent looking for codeblocks in my settings file - who knew it would be hidden?). I even compiled "hello.c". It takes up 23kb???!!! I think I have to read the manual.
    edited 2010-02-07 22:31
    Hi mwalimu,
    Glad you got it sorted. Let me know of anything you had particular trouble with and I'll try and make it clearer in the documentation for the next release. I don't get the bit about Code::Blocks settings being hidden - can you explain?
    The "Hello, world" program compiles to 23k only if you include floating point support in the stdio routines (i.e. compile with -lc). If you compile with the integer-only stdio routines (-lci) it compiles to 15k. If you use the Catalina alternate I/O routines (see hello_world_1.c) it compiles to 8k. If you then also omit the (unused) keyboard and mouse drivers (using -D NO_KEYBOARD -D NO_MOUSE) , it compiles to around 6k.
    In all cases, the actual 'main' routine is 11 instructions long. The remainder consists of:
    • the kernel itself - this space is re-used as stack/heap/data space at run time.
    • the HMI (video, keyboard and mouse) drivers - this space is also re-used as stack/heap/data space at run time.
    • the library support code (stdio in particular is quite large).
    For comparison, gcc compiles "hello_world" down to 16k on a windows PC - and Catalina has to include ALL O/S support, whereas the PC executble does not.
    Ross.
    Post Edited (RossH) : 2/7/2010 10:58:38 PM GMT
