which analog simulator software would you recommend
StefanL38
                    For a friend of mine I'm searching for a simulator software that is MOST easy to use for SMALL and BASIC circuits.
The target is NOT NOT NOT
having the most parts that were simulated most accurate at any frequency/current/voltages
The target HERE is to learn the PRINCIPLE function of electronic components and that the software is easy to learn
(how to add components, how to connect them, how to examine voltages over time
And / or a tutorial for real beginners
best regards
Stefan
best regards
Stefan
www.falstad.com/circuit/
This is a nice applet, which will get many items covered with respect to operation. I'm not sure of any for basic principles of meter usage.
I hope this helps,
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
I played with it 5 minutes and my first impression is: VERY GOOD!
To give a real judge I will have to play for an hour with it
thank you VERY much for this link !!
best regards
Stefan
Glad it helped.
I use it to keep my mind straight about circuits I'm working on. I'm not an analog guy, so I have to work hard to get analog circuits right.
James L
James L
Partner/Designer
www.linear.com/designtools/software/
It is free, you can use any spice model (not only from Linear), and the yahoo group is really active.
Massimo
Livewire:
www.new-wave-concepts.com/pr/livewire.html
All Products:
www.new-wave-concepts.com/products.html
Like max72 I also use LT spice from linear.
