stripboards in the usa?
Okay- so I have a question. When I was in the UK, I used 'veroboards' or stripboards which seemed to make prototyping a lot easier. For circuits that just wont fit on a breadboard (high amps and such) this was great. But I just can't seem to find any vendors that sell stripboards in the USA. So why are they so hard to find?
Anybody know of a few good vendors? I see I could get some stuff on 'ebay' but most of the suppliers are from UK.
http://www.mpja.com/products.asp?dept=284
Post Edit -- Oh, that's 'stripboard' then?· I've been at this a long time and haven't seen that before.· I've used one of those tools, I guess, but as a "pad cutter."· Anyway, I'm into fiberglass with plated-thru holes with a ground plane on one side; that's how I've done almost everything·for > 12 years.· I've done some PCBs·with ink-blobs·on copper and·still some hacked "protoboards", too, if convenient/warranted.· Time, effort, my "mood", whatever.
Post Edited (PJ Allen) : 1/14/2010 11:26:57 PM GMT
stripboard looks like this
You essentially use a little 5mm drill bit to remove where you don't want. You can also use a cutting tool for precision cuts to seperate 2 adjacent holes.
Post Edited (OakGraphics) : 1/14/2010 8:51:00 PM GMT
http://www.futurlec.com/ProtoBoards.shtml
www.verotl.com/
Leon
Amateur radio callsign: G1HSM
www.allelectronics.com/make-a-store/item/ECS-4/SOLDERABLE-PERF-BOARD-LINE-PATTERN/-/1.html
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Leon
That's an interesting technique. You must have some form of special tool to cut the holes from the ground-plane. Do you find you do less soldering using this type of board: Is it easy to isolate a 'bus' so to speak? Just curious.
Given plated vector board, you can isolate pads for an IC, but it takes a certain touch to do.
