PowerTwig......... A 5v/3.3v 800mA power supply on a 1/4"x3" PCB
Here's a peek at a new PCB, nicknamed the PowerTwig, that was designed with/by a good friend of mine. The concept has been in the back of my mind for over a year and since he had a PCB with a simple dual power circuit already in use, he harvested that for my concept.
The 5 volt and 3.3 volt outputs are based upon the reference design of the LD1117 using the improved ripple rejection circuit. The 3.3 volt circuit input is coming from the 5 volt output, so the 800mA rating is a combined total current output. By using an adjustable LD1117, you can modify resistor values for other output voltages.
The first few PCBs are awaiting parts install so that the design check can be completed. Once everything is set a release timeline will be available. Right now, it appears that the first batch of PCBs will be in my hands in late Feb.
Attached is a 3D view from Altium Designer (CAD software used for the design) and a picture with a PCB next to a gerber printout and a propstick.
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
Post Edited (WBA Consulting) : 7/22/2010 2:40:47 PM GMT
Andrew Williams
WBA Consulting
What range of input voltage will the Twig tolerate?
The LD1117 by J1 is the 5V regulator and the one by J2 is the 3.3V?
What's the free-air power dissipation of the LD1117?· At 8V input, the 5V regulator will see a 3V drop and at 800mA, that's 2.4W.· Will there be enough heat sink to accomodate this?
DJ
Post Edited (davejames) : 1/12/2010 11:49:55 PM GMT
The main part of my testing will be with varying loads and input voltage levels to see how much it heats up. The maximum output current for the LD1117 is rated at 1.3A and one of my test PCBs will be subjected to that limit.
J1/J2 is the input. (2 pin header or DC jack)
J3 is the 5v output header
J4 is the 3.3v output header
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
Thanks for the follow up info.
DJ
Input: 12.04v (12v power supply, not a wall wart)
Out1: 4.95v (121 and 360 ohm for divider values of LD1117 circuit)
Out2: 3.27v (121 and 196 ohm for divider values of LD1117 circuit)
Andrew Williams
WBA Consulting
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
I already came up with a design improvement. Had I used 1206 size parts for the resistors in the divider networks, they would be much easier for end users to modify for other output voltages. I would like to sell this in kit form mainly, but I am uncertain as to how many people are comfortable with 0603 parts.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 1/15/2010 5:36:17 PM GMT
I also have a 5/3.3/1.8@1.5 amp each supply designed. It is going to pcb soon on a board I designed for a customer.
Although I know it is an after thought, you may want to consider making the board fit a breadboard. That would be nice to have a 3.3 volt rail and a 5.0 volt rail. It would probably require a redesign.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
@james: I never thought of the breadboard fit for this design until I received the first fabs and realized that it almost does fit on my small breadboard. With the limitations of the 1/4"x3" it may be possible to make that change. For now, the first 300 PCBs are made so any changes would be after those clear out.
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
The one thing I would be worried about is breaking it...
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
(no longer new) SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
I have 60 boards ready to build and will have all material next week. My stencil will be ordered Monday and if things go well, the boards will be built the following week.
For now, it will be offered with all SMT parts installed for a 5v/3.3v arrangement. The DC jack and 2 pin headers will not be loaded, but included with the PowerTwig.
Each board will be tested using a 300mA load on each output.
Shipping in the U.S. will be $1.00 in a padded envelope.
I still haven't settled on a price, but will within a week. This isn't a money maker, so it will be kept low. Similar power supplies designed for breadboards run from $9.95 (PRT-00114 Sparkfun) to $13.99 ( MKCI1 MakerShed). I have to review things again, but I think I can beat $9.99. Plus, mine isn't so much designed for use on a breadboard as it is meant to enable an easy way to put a finished project in a box using a 12 or 9 volt battery and only need a basic prop circuit on a piece of prototyping board.
Andrew Williams
WBA Consulting
These will be on sale at UPEW for a special price of $10. This will include:
1 powertwig built up as shown in the picture
1 DC Jack, 2.1mm
3 Two pin headers
A few of these will be in the raffle as well.
Andrew Williams
WBA Consulting
The second picture is of the kit contents (DC Jack, three 2 pin headers, and the PowerTwig)
The last picture is the modification needed for the DC jack. It will be supplied with all three pins left on in case you want to use it for something else and use the 2 pin header for input to the PowerTwig. For use on the PowerTwig, just bend the side leg up until it breaks from the housing since it is not used.
Andrew Williams
WBA Consulting
www.powertwig.com
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 6/21/2010 12:48:02 AM GMT
I like the way this power supply looks, it's cute!
Could you produce a version for people with batteries?· I'm thinking of 9 volt·or 6 volts (1.5 AA batteries times 4).
I'll probably just use a voltage regulator until then.
Post Edited (Chuckz) : 6/27/2010 4:19:09 AM GMT
Chuckz. I am not sure I understand your question, because this can be used with batteries. I am using one with a 9 volt battery for my plungelogger and in the same way for the metronome (see the links in my signature). The DC jack is supplied unsoldered so you have the option of using it with or without a wall wart. With a 9 vot battery, just solder the wires from the battery clip to the 2 pin header right behind the DC jack (J2 location). The square pads are all tied to ground.
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
http://www.gadgetgangster.com/find-a-project/56?projectnum=358
It never occurred to me to check the spacing between those headers. I guess I assumed they'd both be usable with a breadboard. I was thinking about placing them across the breadboard and using jumpers to get to the bus on either side (3.3 on one side, 5 on the other).
It's a nice looking board and I'm sure I'll be able to adapt the ones I ordered, but I look forward to a V2 with the "fixed" spacing.
I am working on a "connection kit" that will be added to future PowerTwigs. It will consist of a set of six 6" long wires with Molex SL crimps on one end and tinned wires on the other. 3 will be red and 3 will be black. Three 2 pin housings will also be included. This will enable you to have wires coming from the PowerTwig to plug into breadboards, etc. It will greatly increase the use of the PowerTwig. I am also looking at using Tyco MTA connectors in place of the Molex SL, because that involves a single part that requires less time to attach wires. I'll update this thread when I get there and will make sure you get a set(s).
My plan is to have two of the cables with each PowerTwig so they can be used for the outputs. The cables are made from 24AWG zip wire with the white stripe meant to be used as positive and connected to pin 1 of the connector.
The "PowerTwig with Leads" proto in the picture also has a 9 volt battery snap instead of the DC jack. In this manner, the wires can be laid flat onto the board giving a very low "in-line" profile that can be enclosed in heatshrink.
I'll have a bunch off to GadgetGangster soon and we will update the product page once he has them.
Do you foresee any problems with heat dissipation?
